The task of seeing if it would run started at the fuel tank. It was obvious as I loaded it on the trailer it was leaking and smelled of old fuel. After pulling it, I found it was rotten at the seam and from searching found the Foxbody tank was a doable swap. So, a new tank, 255 pump, an attempt at a sending unit and fabbed filler neck got that problem fixed. I removed the second fuel pump. A fresh battery confirmed we had fuel pumping with no leaks.
With the fresh battery I tried cranking it and found the next issue. I had starter noises but the motor wasn’t moving. So, I pulled the starter and found the spinning but was trashed and not engaging the flywheel. I believe was the reason it was parked. A new starter on got me a motor that spun over nicely, to nice actually. The timing belt was split. It’s been 10years since I played with a 2.3t but I remember how to do a timing belt.
New timing belt on it and I had spark and fuel pressure, it would crank over but not start so I went over all the grounds and hots. With starting fluid it would run for a minute so I pulled the brown tops and with berrymans cleaner I flushed all 4. Put them back in and it fired off and ran like it had been running the day before. Someone had cut the exhaust where it crosses under the transmission so I got full tractor/turbo noises. It had been a long time since I heard that and I kinda missed it.
Well, let’s see if it’ll move, put in gear, little gas and it moved. Yes! Clutch seems good, trans didn’t make any funny noises and rear end didn’t either. I let it run and get some heat in it. Afterwards I changed the oil and filter and topped the coolant off. I noticed most of the gauges don’t move in the dash so I can’t confirm is my attempt at a fuel gauge works, the vacuum/boost gauge works and the tach is low and temp gauge is dead. I confirmed the fan works by jumpering the fan switch but have yet to see if come on.
I noticed a miss and decided the plug wires have seen better days as some mice made a snack out of them. I’ve never seen wires labeled with a date and by number. I’m guessing they were factory.
We’re up to date, I ordered some 195/60/14 tires for the stock wheels. Going to put some fresh paint on the wheels when I put them on. I’m still not sure if I’m gonna connect the exhaust back or leave open down pipe and keep sorting thru the issues of a car that’s been sitting.
