Painting the Plastic Bumper Cover
Hello! I am interested the color in which the toupe was painted (bumper, moldings and grille). Who knows the color code?
Re: Scorpio Change Delineation Thread
See below for US spec cladding paint.
I am not sure is the cladding colors match up with those in Europe. However I do know that the cladding paint is available in Europe as I have seen it on ebay.uk and other outlets and available in rattle can spray.
Thanks a lot. This is valuable information.
The only problem is that the products mentioned in that TSB are 30 years old and probably no longer available.
I have often considered repainting my own cladding. If I were to do so I think I would acquire modern acrylic lacquer and see if there is a modern flexible additive equivalent available. I would then get gray and silver paints and mix them myself to match the color of my current cladding.
The other alternative (available in the US) is to find a somewhat close match from SEM products...
https://www.semproducts.com/product/bum ... m-aerosols
Here is their color chart, but it is hard to discern a match for the Scorpio
https://manage.semproducts.com/public/c ... 18_web.pdf
PM BlackBart. One of MCA's most experienced painters.
Re: Painting the Plastic Bumper Cover
I split this topic off on it's own thread as it was going off-topic (but still a valuable topic). I'll add my 2 cents, that we used Epifanes 2-part Polyurethane Yacht Coating on the Scorpio, both the body and the bumper covers. There have been zero adhesion problems to date.
https://www.epifanes.com/page/poly-urethane
Interesting. Wonder if it ships to CA. What color on their chart did you choose? I take it you sprayed it on. I've heard of a guy out here who actually rolls auto paint on in a few coats (like house painting) with light color sanding in between. Takes obviously longer, but I'd think you'd have to have a booth to do it right, but then you're already enclosed so why not spray? Only issue with the epifanes might be the 24 drying times.DPDISXR4Ti wrote: ↑Sat Mar 05, 2022 10:47 am I split this topic off on it's own thread as it was going off-topic (but still a valuable topic). I'll add my 2 cents, that we used Epifanes 2-part Polyurethane Yacht Coating on the Scorpio, both the body and the bumper covers. There have been zero adhesion problems to date.
This color.... The base color was custom-mixed, all rolled on, with three other factory colors "wet-splashed" in with a brush for the final coat. Imagine 4 colors going on at once, all 2-part. Yes, it was a fire drill.john keefe wrote: ↑Sat Mar 05, 2022 8:34 pm Interesting. Wonder if it ships to CA. What color on their chart did you choose? I take it you sprayed it on. I've heard of a guy out here who actually rolls auto paint on in a few coats (like house painting) with light color sanding in between. Takes obviously longer, but I'd think you'd have to have a booth to do it right, but then you're already enclosed so why not spray? Only issue with the epifanes might be the 24 drying times.
Since this is designed as a boat paint, it's designed to be rolled but certainly it can be sprayed. The long cure time is a plus - it means you don't have to sand between coats. It's really good paint - it's meant to be on a boat that is outside all the time.
That's encouraging. I'd be spray painting a lot of repairs (or even the whole car(s)), except the fumes wouldn't get a good reception from the neighbors or the city. So, long drying time = pretty smooth and not much color sanding?
No door or rocker panel claddings? Looks pretty good, and makes sense as you used the doors for a canvas. I take it that's for a swim club/coaching billboard. Who's the model? I can imagine getting in trouble with that, if its the wife/girlfriend... they could either be thrilled, flattered, or embarrassed. If its not of them, then jealous of it, or pissed off that you'd actually do it.
Why'd you go with the two-part poly instead of the yacht enamel or mono-urethane? Harder cured-coat? But, fewer color choices.
Did you mix two or more of the poly colors, or use a compatible color additive/tint?
The only sanding we did was the epoxy primer. After that it was just a tight time-schedule so that we could rely on a chemical bond rather than physical.john keefe wrote: ↑Sun Mar 06, 2022 2:22 pm So, long drying time = pretty smooth and not much color sanding?
We both decided early-on that the cladding was coming off and never going back on. My wife is a swimmer so it was all her design, just for the fun of it. The right side of the car - what you see above - is closest in looks to her. The other side has darker-haired swimmers.john keefe wrote: ↑Sun Mar 06, 2022 2:22 pm No door or rocker panel claddings? Looks pretty good, and makes sense as you used the doors for a canvas. I take it that's for a swim club/coaching billboard. Who's the model? I can imagine getting in trouble with that, if its the wife/girlfriend... they could either be thrilled, flattered, or embarrassed. If its not of them, then jealous of it, or pissed off that you'd actually do it.
Longer-lasting, better UV resistance, and better leveling when rolled.john keefe wrote: ↑Sun Mar 06, 2022 2:42 pm Why'd you go with the two-part poly instead of the yacht enamel or mono-urethane? Harder cured-coat? But, fewer color choices.
We sent them a sample to match. That only gets done in Holland so it took some time. I actually do NOT however recommend that, as they didn't get it right. Long story, but stick with the factory colors. Those can be inter-mixed, although they will tell you that you shouldn't, so you're on your own.
Good info considering I want to put the smooth/later cladding on my 86...
And... you're complaining about what, again?DPDISXR4Ti wrote: ↑Sun Mar 06, 2022 4:45 pmMy wife is a swimmer so it was all her design, just for the fun of it. The right side of the car - what you see above - is closest in looks to her.
Just bear in mind, it's very glossy. That gives it a lot of depth, but I'm not sure how well that might play against the factory body paint.
