New to forum Intro
Cool_story_bro
New to forum Intro
Post by Cool_story_bro »
If this is the correct place for a new form intro then I would like to say hello as well! :cheers I just got a hold of a 1986 manual xr4ti that has a confirmed 30,000 miles. When I bought it it came with a box of receipts that track all the way back to 1991 with over 10k of maintenance and repairs and every single re-registration that it's had from its one owner. As The story goes a couple of kids got it and started to rip it apart and build it up as a rally car. and then found another that doesn't have the sunroof so they left it as is and I picked it up. What I've discovered as I've dug into it so far, is an aftermarket radiator, a brand new master cylinder for the brakes, new timing belt, new accessory belts, new CV axles, new coolant hoses, an aftermarket suspension from 1995. 5cc over stock. injectors and a non OEM computer. The battery relocated to the rear and it also came with a heap of extra parts and things that they hadn't put on yet.
The wiring is a complete nightmare. But I'm going through the paces of giving it the TLC It needs.
New plugs, wires, cap and rotor. ReTimed 18°out,vacuum hoses replaces. Coolant drain, flush, full w/ new cap.
Coming up is oil pan gasket and change ( hoping it fixes a sticky lifter in #4)
Also I just acquired a full dealership service manual. I would love to answer any questions to help out.
Cheers from Arizona :cheers
MarkM
Re: New to forum Intro
Post by MarkM »
I'm splitting your post off into its own thread. Two separate discussions about new members and their cars in the same thread is likely to get confusing, quickly.
Also, could you elaborate on what "ReTimed 18°out" means? I have some concerns about that.
Welcome to the forum!
Mark
mfks
Post by mfks »
Awesome welcome I look forward to following your journey. I too just picked up an xr4ti.
Chris
88 xr4ti
Northern Illinois
MarkM wrote: Wed Apr 20, 2022 2:33 am
Probably re-time it as the previous owners had it 18° out (of time).
To the original poster, welcome! :cheers
If your 1986 has a "late" oil pan (all the bolt heads are the same size) the 1 pc rubber pan gaskets are getting tough to find.
They're in stock at www.merkurdepot.com though
Cool_story_bro
MarkM wrote: Wed Apr 20, 2022 2:33 am I'm splitting your post off into its own thread. Two separate discussions about new members and their cars in the same thread is likely to get confusing, quickly.
"ReTimed 18° out", meaning I set the timing to 18° retarded from tdc it was set at 8° when I checked it and the throttle was laggy and bogged down. Now that it's -18° it's very responsive and spools a lot quicker
Cool_story_bro wrote: Tue May 17, 2022 11:04 pm
Timing should be roughly 10degrees BTDC if this is a stock cam.
Sounds weird. Are you checking the timing with the spout connector separated? I would check the timing belt to see if someone installed it incorrectly or it jumped time. Timing would be 13 degrees if you have a 5 speed computer and 10 degrees if it has one from an auto/mustang/thunderbird etc. What computer do you have? What VAM do you have? Do you have some injectors other than brown top injectors? If it has been sitting awhile and you suspect a sticky lifter I would pull that valve cover. You might as well clean all carbon from the entire intake system and any sludge from the valve cover. You could soak the lifters and reinstall them. Check to see if there's some other issue like a broken valve spring.
