XR LED upgrades (Interior, Exterior, etc)
Special deals from our sponsoring vendors.
Moderators: John Brennan, DPDISXR4Ti
Cleat
Re: XR LED upgrades (Interior, Exterior, etc)
Post by Cleat »
Regular stock bulb.
Gives me just enough load for the flasher to be happy.
I was able to squeeze a clear 1156 LED bulb in the footwell, dome (with a modified setup using footwell light fixture), rear hatch, and underhood locations.
Nice and bright.
GT350RS
Post by GT350RS »
Interested in the cluster bulbs and Clock bulbs. Do you want the old sockets first or can they be sent after the swap?
'87 XR4Ti - Blue Grey Metallic - Moonroof - All Original - 98K mi
'16 GT350 - Triple Yellow - Black OTS - Lund Tuned
'17 Focus RS - Stealth Grey - FR Tuned
'05 S2000 - Suzuka Blue - All Original - 34k mi
'02 A4 3.0 Quattro - Light Silver - All Original - 68K mi
DAReese
Post by DAReese »
SvoSierra wrote: Sat Jun 27, 2015 9:55 pm Information: If you are going to run LED turn signals, here is the modification needed for the STOCK flasher relay behind the dash. If you need more info on finding it, look in your shop manual. Carefully open the STOCK relay and snip the lead on the integrated circuit as shown in the photo. Easy as that, no $30 special relay needed.
For those doing the LED swap, Superbrite LED has a flasher that is plug and play that eliminates the need to dissect and rely on a thirty-year old flasher for $12.97. e-Bay has them for even less. EP-27 is the one I got, works fine. The only issue I have is the noise is less than OEM, so you can't always hear that your turn signals are on, especially with a 3" exhaust.
David Reese
Jayrod82
Post by Jayrod82 »
Howdy! are you still making the Dash cluster LED's? if so how do I order a set?
James Wieler
Post by James Wieler »
Can anyone advise on how to remove the dome light cover? I hear they are brittle so I want to make sure I'm prying on the right spot.
thanks
James
T3/T40E-50 trim, 3" exh, FMIC, gutted/rotated upper, ported lower intake,60mm T'body,big valves,big VAM,LA3,1990 5.0L WC T5 0.82 5th gear, Cossy sway bar, Powerflex, Dynalites, Focus SVT rotors,Koni yellow sleeve over 8"x300lb/in springs,Scorch bumper cover, 17x7.5x40mm Binno wheels, 225/45-17 Kumho 712 tires
DAReese
Post by DAReese »
James Wieler wrote: Sun Oct 14, 2018 10:12 pm Can anyone advise on how to remove the dome light cover? I hear they are brittle so I want to make sure I'm prying on the right spot.
thanks
James
Very carefully. I use a paint spatula in order to spread the stress over a larger area. It can't flex too much, but a little flexing is OK. I've been fortunate, as it seems none of mine don't look as brittle as some of them I've seen.
David Reese
DAReese
Post by DAReese »
Just wondering if it would make more sense to buy a new relay instead of altering a 30+-year-old one?
David Reese
DAReese wrote: Wed Oct 17, 2018 2:53 pm
thanks
James
Ideally try to insert the drywall spatula or broad putty knife where the spring clips are that retain the cover in place. Search for a photo of one removed from its base to guide you re the location of the two springs.
DAReese
Post by DAReese »
Ed Lijewski wrote: Wed Oct 17, 2018 4:15 pm
thanks
James
Yep, that's what I meant.
David Reese
Merkurfast
Post by Merkurfast »
How about the Scorpio? Any advice in removing the overhead console to replace bulbs?
DAReese
Post by DAReese »
They're easily replaceable. Ford used that light for years in many models.
David Reese
Merkurfast wrote: Sat Nov 03, 2018 8:37 pm How about the Scorpio? Any advice in removing the overhead console to replace bulbs?
Wish I had taken a photo...from memory:
The surround cover is held in place on two sides, IIRC the left side slides under a metal tang, and the right side by a metal screw. To remove it, remove the screw, then gingerly tap on the surround to release it from the tang.
