NEW 85-88 XR4Ti Aluminum Coolant Tanks Now Available
Special deals from our sponsoring vendors.
NEW 85-88 XR4Ti Aluminum Coolant Tanks Now Available:
https://www.ebay.com/itm/192583927170 ( <- ebay link. If you don't use ebay or prefer to buy one directly: merkurdriver@gmail.com )
New MERKUR DEPOT aluminum coolant expansion tank for RH right side mounting location.
Requires bolts ran upwards from the bottom creating a threaded stud in the engine bay. Once you have a threaded stud in place nylon or rubber spacers can be added before the tank is fitted to adjust the height of the final tank mounting as it will need spaced away from the body of the car (picture shown to illustrate mounting technique).
Installation is simple, but if you are concerned with mounting hardware we can supply bolts and spacers upon request.
Primarily designed to compliment our "shorty" aluminum radiator installation in 1985-1988 Merkur XR4Ti, however it can easily be used as a replacement for stock (XR4Ti) set ups using one of our silicone Y hoses that eliminate the need for the middle hose on the coolant tank.
Ersatz36
Re: NEW 85-88 XR4Ti Aluminum Coolant Tanks Now Available
Post by Ersatz36 »
I bought one from the eBay store, is there a way to get the silicone hose shipped in the same box?
Yes, I'll send you an email directly.
Power Tryp
Post by Power Tryp »
Please tell me these will be making a come back.
Ford Parts Geek.
87 XR4TI
80 924 Turbo
I have 2 of them on hand / in stock / ready to ship:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 2361157885
Power Tryp
Awesome! I've ordered up. Thanks for making new and awesome items for these cars. I'll be in for a rad and probably hoses in a little while too,
Ford Parts Geek.
87 XR4TI
80 924 Turbo
Just one left:
https://www.ebay.com/itm/192593444157
(Starting the drawing for 1989 XR aluminum tank...)
Ersatz36
Post by Ersatz36 »
I agree, thanks for helping keep these things on the road, got mine last monday and it looks great.
Power Tryp
Just got my tank last night and it looks awesome! Thanks again for making new cool $#!* for these cars.
Just as a question, roughly how long are your spacers? I'd like to avoid the possibility of a bolt backing out and falling into the wheel well area so I figured I would use a nutsert/riv-nut and a couple of these guys in the right length,
Cheers!
Ford Parts Geek.
87 XR4TI
80 924 Turbo
The spacer length on the rear mount is 1.25" and 0.75" at the front. *Also add the thickness of a lock nut that resides underneath to hold steady as a stud.
timxr8
Post by timxr8 »
merkurdriver wrote: Fri Jul 13, 2018 2:58 pm The spacer length on the rear mount is 1.25" and 0.75" at the front. *Also add the thickness of a lock nut that resides underneath to hold steady as a stud.
So ~ 1.5" rear and ~1" front
Tim Spencer
timxr8 wrote: Thu Aug 16, 2018 7:20 pm
Basically, yes. On the new batch of tanks (10-8-2018) the locations of the mounting tabs have been moved to allow shorter spacers. (I have 1/2" rubber isolators on the one I just used for a test fit.)
85-88 XR4Ti coolant tanks back in stock at www.merkurdepot.com -> Aluminum Coolant Tanks
