Like clockwork...ECT failure..
Post by brokencase » Mon Jul 13, 2020 6:50 pm
After finishing my re-upholstery and lumbar stuff...
..she starts stumbling off idle., Gets better as it warms up.
Today I decide to pull codes.. Code 21 ECT out of range..tell me something I don't know...
I am about 87K on this '88. I would say this failure is within 4k miles of the ECT failure I had in my previous '88 Scorpio.
What was the difference? This time I had to pull off the throttle body to get the ECT to crack loose. It was "fused on" after 30 plus years.
I just could not get enough umph behind it to break it loose. Ended up chopping off the plastics so I could get a socket over it.
Last time I did not have to pull off the throttle body. All I had to do is sneak an adjustable over it
Anyhow..got it back together, cleared codes, and took her for a long drive. All is back to Scorpio bliss...
I wonder how long the cheap aftermarket ECT will last... I got it from Advanced Auto for $17. Didn't want to wait around for a RockAuto item..
Re: Like clockwork...ECT failure..
Post by andyofcolumbusmerkur » Tue Jul 14, 2020 10:08 am
You should write a book.
Post by DPDISXR4Ti » Mon Jul 20, 2020 10:25 pm
Probably an age-related failure more than mileage. We should make a list of things to just proactively replace at this point.
Merkurfast
Post by Merkurfast » Mon Jul 20, 2020 10:51 pm
What is a ECT again?
Post by DPDISXR4Ti » Tue Jul 21, 2020 12:07 pm
Engine Coolant Temperature
Post by brokencase » Wed Jul 22, 2020 9:12 pm
I think it is more about number of heat cycles than it is mileage or age.
Its been running OK with the new sensor, but I think i'm going to pull codes again tomorrow just to be sure..
Post by john keefe » Mon Aug 03, 2020 12:16 pm
Just checking... Looks like the same ECT sensor for the XR (RockAuto parts). Is it?
Post by DPDISXR4Ti » Mon Aug 03, 2020 1:24 pm
I'm pretty sure most everything Ford from the mid-'80's to '94 used the same ECT. Even the OBD2 version starting in 1995 has the same transfer curve, just a different quick-connector.
