DPDISXR4Ti wrote: ↑Thu Jul 28, 2022 2:17 pm
For the lamp connection, did you just run the other end to the battery GND?
No. You will need a test bulb to bench test the alternator.
As I said over and over. One side of the bulb goes to +12v. The other side of the bulb goes to the lamp connection on the alternator. With the alternator NOT spinning the bulb will glow. When the alternator spins the Lamp connection side will rise to +12v. You will then have +12 on both sides of the bulb and it will go out.
Lets review the alternator bench test...
On the garage floor we have...
A car battery
An alternator
several big clip leads
a drill rigged with a socket that can spin the alternator
A DMM
a 12v light bulb. Preferably with two wires soldered to it.
1) connect the case of the alternator to the battery negative terminal with a clip lead (or jumper cable)
2) connect the output stud of the alternator to the battery positive terminal with a clip lead.
3) connect the S (sense) of the alternator to the battery positive terminal with a clip lead.
4) connect one side of the 12v light bulb to the alternator LAMP , the other side of the bulb to the positive terminal of the battery. Note that the bulb glows at this time.
5) hook up the DMM to measure the battery voltage.
6) spin the alternator with the drill. Note that lamp goes out. Note that voltage across battery rises slightly.
