So the Astro pump is key here because it uses a straight snout vs the majority of the Saginaw pumps that have the tapered version. Were there other Saginaw pumps with a attached reservoir and a straight snout?
That and the horseshoe adapter bracket really make this a bolt on affair aside for the clearance of the bracket.
Great work Brad.
Saginaw Power Steering Pump Conversion
Re: Saginaw Power Steering Pump Conversion
Jeremy Kemp
RIP: the Mutt….1988 XR4Ti Chestnut Brown/Spice Leather
MC2 Coilovers and Bushings, Contour Rims and Rotors, Ported Motorsport Head, Cosworth 4x4 Intercooler, Holset HY35 Turbo, 80LB Injectors, Megasquirt2 EFI
Actually, from what I've observed, most all of the Saginaws use a straight shaft, not tapered. That's certainly the case with the one I now have on my F-150, which does indeed have an attached "canned ham" reservoir. That was a much easier swap though, as the Saginaw pump is used on the Ford E-series vans, so I was able to just grab everything (pump, bracket, hose) from the donor van.jkxr4ti wrote: ↑Mon May 27, 2019 11:14 am So the Astro pump is key here because it uses a straight snout vs the majority of the Saginaw pumps that have the tapered version. Were there other Saginaw pumps with a attached reservoir and a straight snout?
Great work Brad.
I think there are clearance issues trying to use the horseshoe adapter bracket with anything other than the remote reservoir pump. I didn't investigate it much - it's just what I was told. I considered trying to make my own adapter bracket from an Astro bracket, but I quickly realized that would be a futile project. I have a spare Astro pump at this point - if you want it for $20 I'll bring it along with me to Carlisle.
Agreed, documentation here and then a final parts list...John Brennan wrote: ↑Thu May 23, 2019 9:21 am I admire all the work you've done on this, Brad, especially the exquisite documentation. I wish I had that kind of spare time.
I've put about 40 miles on the car, which I'm calling "good enough" for the upcoming 500-mile test. The pump is all but silent, even under low-speed turning maneuvers. I'm happy with the final results.
The pump passed it's 500-mile test last week with flying colors. I was a little apprehensive about using a 3/8" barbed fitting to "create" a hybrid hi-pressure hose, but it has not leaked at all - bone dry on either side of the fitting. Maybe some day I'll have a hydraulic hose shop make up a hose, but for now all is well.
1,000 mile circuit next: Tuxedo to Saginaw to Detroit and return home.
I'll create a listing when I get a chance, but I realized yesterday that I've accumulated a second batch of most of the parts you need to do this swap, which I'd be willing to sell. At his point I have the following:
- Astro pump w/ Reservoir
- Lower pressure regulator from Saab
- Pulley with correct offset
- Spare bracket for "re-fabrication"
Drop me a PM if interested.
<Edit March 2023 - sold the extra stuff indicated above - I do however have another couple brackets if someone needs one>
