T9 Clutch Reservoir?
Chris_12
Post by Chris_12 »
I pulled out my 87 XR out today. The pan had a bit of red fluid. My dad and I were not sure where it came from. I thought it came from his RX7 that needed the clutch replaced because we slid the pan under my car, but he wanted to check the clutch reservoir on my car. We spent 20 mins looking but couldn't find it. I have to ask the question: where is the clutch reservoir for a XR with the T9 transmission?
'89 Merkur XR4Ti Racecar-The Beast
'88 Merkur XR4Ti-The Build
'87 Merkur XR4Ti-The Beauty
Always looking for a '85 Merkur XR4TI (blue preferably) for my dad
jkxr4ti
Re: T9 Clutch Reservoir?
Post by jkxr4ti »
T9 is a cable clutch so no reservoir. If the fluid was red it’s likely type f transmission fluid as used in the power steering system.
Jeremy Kemp
RIP: the Mutt….1988 XR4Ti Chestnut Brown/Spice Leather
MC2 Coilovers and Bushings, Contour Rims and Rotors, Ported Motorsport Head, Cosworth 4x4 Intercooler, Holset HY35 Turbo, 80LB Injectors, Megasquirt2 EFI
reddy2300
Post by reddy2300 »
T9 fluid is also (likely) red.
1987 XR4ti--Mustang Cobra 5.0/T5 transmission, AFR heads, fake BBS wheels, Koni Yellows, Rapido sway bars, poly/aluminum bushes, Eurolights, Sierra rear/Focus front discs,
Post by hEaT »
Power steering fluid/ATF is red, I think? Been a while since I had any, and that commonly leaks on the XR.
^^^ I was losing PS fluid but wasn't able to find the leak source as I was too busy for weeks. Replaced pump, return hose, rack ... turned out the high pressure hose, which I had checked and appeared in good condition, had a light wear section not easily visible that rubbed on something near it. Replaced it. No more PS fluid leaking.
BTW, that fluid aggressively stains asphalt (car was parked on street then).
Chris_12
Post by Chris_12 »
Thanks everyone.
