Accidentally shortened Steering Shaft - Bearing Installation Tips
- John Brennan
Re: Accidentally shortened Steering Shaft
Excellent-- made your own slide hammer, I see.
Sorta, kinda. At first it was the vise-grip that was only sliding as I wacked it with the hammer. Then I bit down a little harder with it and gave it another go. This time the shaft moved. Yea!!!
- John Brennan
So, do you have it back together? As Bob Dylan would say, "How does it feeeel?"
Got it all back together last night, only to find that the battery was dead. Not sure if it's dead-dead or just in need of re-charge. Left it on the charger overnight.
- John Brennan
"It's only mostly dead..."
I really want to do the scorpio steering column swap on mine, along with this bearing.
Had I known about the bearing at the time, I certainly would have done it while the car was gutted (which clearly was the time to do the Scorpio steering column swap). But it's not that tough to do just the bearing install on a fully outfitted car. I have a spare steering shaft that perhaps I'll bring to Carlisle along with another batch of bearings. I drove the car with the bearing installed for the first time last night. It's an awesome upgrade, even more so if you're running manual steering.
Just had a question about the after-market steering bearing myself and others have sold not being mounted quite level with the housing. In short, it's not an issue since it's a mild-interference fit and will shift if needed on it's own. If you want to level it up prior to install, just tap around the perimeter of the bearing to level it up with the housing. Just be sure not to hit the seal as you can damage the bearing that way.
Thank you!DPDISXR4Ti wrote: ↑Thu Jan 10, 2019 12:33 pm Just had a question about the after-market steering bearing myself and others have sold not being mounted quite level with the housing. In short, it's not an issue since it's a mild-interference fit and will shift if needed on it's own. If you want to level it up prior to install, just tap around the perimeter of the bearing to level it up with the housing. Just be sure not to hit the seal as you can damage the bearing that way.
This is a good upgrade. it was original on Group A cars with similar bearing. But not "collapse" colum om them either, since Are only a straight shaft on them
I have a loose scorpio column around here someplace. Make me an offer. Or maybe trade for some xr goodies.
Re: Accidentally shortened Steering Shaft - Bearing Installation Tips
Great. Another mod. What's the advantage of the Scorpio column?
Says Columbus, but where are you located? Or PM me and we can do details....andyofcolumbusmerkur wrote: ↑Fri Jan 11, 2019 6:22 pmI have a loose scorpio column around here someplace. Make me an offer. Or maybe trade for some xr goodies.
Scorpio column has adjust lever.
email: xxxxxx@yahoo.com
cell: 234-xxxxxxx
I will delete all this in a day or so. I hate robots calling and texting me.
cell: 234-xxxxxxx
Last edited by andyofcolumbusmerkur on Mon Jun 21, 2021 11:05 am, edited 1 time in total.
