Glad you posted that link - I did not know MD made aluminized versions now, which is cool.
The decision point comes in that Stinger's two-piece option (elbow + DP) is quite a bit less than MD's 1-piece. For me, I *want* them in two pieces so I can add a flex section... paying the premium to save fitting them together isn't worthwhile to me. I will say that it look like Mike also addresses the swingvalve portion of the flange, which Stinger does not. Mixed bag, as that additional welding does draw attention I don't want, but I'm sure it's a performance improvement.
FWIW, I talked to Stinger and the "also fits Merkurs" refers to the fact that the generic fox body bends result in tight clearance on the XR's chassis brace. They indicated that if used in combo with the 3" downpipe (where welding is required) there is no issue with fitment.
I crawled under the car yesterday and remembered what I had the shop do way back when:
I had them add a 3" section before the cat so I would have room to add a flange in the future. Close enough!
If I build my downpipe with a flex section I will need to also build a bracket to support the cat. Right now it's basically hanging from the turbo, which isn't ideal but it's been like that for 12 years. If that rigid connection is gone the rest of the exhaust will just flop around, so I need to device something there, probably off the trans bracket. NBD.
Edit: The E6 is already massively ported and ceramic coated in & out. TBH, the current config works very well as a road car, even with only 12psi. The turbo spools very fast, lag is minimal, and it's rare I find something I can't overtake. No, it's not gonna pull a Z06 on the highway, but I really don't need more incentive for racing on the street. My 0-80 capabilities are excellent... I'm not sure what I hope to win with the downpipe other than satisfy decade-old curiosity.
