Euro/horn turn-signal switch conversion to our turn-signal switch with cruise:
Here's some pictures & comment of what I did. I have it currently working perfectly in Raven.
- Compareswitches.jpg (28.68 KiB) Viewed 3396 times
Ron
1989 Merkur XR4Ti - Magenta [My XR]
1988 Merkur XR4Ti - Bunny [Wife's XR]
1988 Merkur XR4Ti - Raven [Daughter's XR]
1985 Merkur XR4Ti - Wombat [Youngest Son's XR]
1997 Dodge Ram 1500 4x4 5.9L - Betsy
2002 Buick Century Custom - Daily Driver
1968 Dodge Charger 383
Re: Euro/horn turn-signal switch conversion to our turn-signal switch with cruise:
First it took apart the broken switch with cruise cause I needed the pin with the tab.
Note. You will have to drill out the rivits carefully.There are 2 other pins that each have tabs which can be used to make the same pin/tab combo. So 1 broken cruise switch can be used to modify 3 euro's.
- Step1.jpg (27.12 KiB) Viewed 3395 times
Ron
You will have to remove the wire with a solder gun. Carefully use a Dremel to cut the bent metal piece out of the way in the channel the wire will follow up to & to also make a indentation so the tab will be flush with the plastic.
- Step2a.jpg (42.3 KiB) Viewed 3395 times
- Step2b.jpg (47.23 KiB) Viewed 3395 times
Ron
The solder wire to tab, carefully press pin in place while guiding the wire in the channel.
- Step3.jpg (42.3 KiB) Viewed 3395 times
Ron
