Agreed! I'm not saying they aren't, just that the input shaft on the 94+ is longer due to the whole car being longer. I think the 94+ also has a better gearing option?thesameguy wrote: ↑Wed Nov 20, 2019 7:38 pmI think the last V6 SN95s are every bit as strong as the V8 version... there's a whole thread about that from maybe 18 months ago I need to dig up!
Awesome. A new noise!
Re: Awesome. A new noise!
Thanks for that! I printed it to PDF and save these kind of things for later use/reference.thesameguy wrote: ↑Wed Nov 20, 2019 10:20 pm Here is the thread... I need to reread it!
viewtopic.php?f=30&t=32229&sid=4c0db17a ... 0f71933c3f
I should definitely do the same... seems like I'm going to need to rely on it twice!
- John Brennan
That's the beauty of this Forum, vs., say, Facebook... I frequent both, but we should never forget where the real, searchable library and repository of facts is to be found!
I never have had and never will have a social media account of any type, so you can count on my never forgetting about the forum!
MCA Forum is like bible study or executive board staft meetings (reserved, protocol infused, formulaic, with approved meeting summary notes).
MCA FB is the array of Forum topics plus even more but like Carlisle parking lot open-ended bench racing sessions.
FTFY!Ed Lijewski wrote: ↑Thu Nov 21, 2019 6:33 pmMCA FB is the array of Forum topics plus even more but like Carlisle parking lot open-ended bench racing sessions where there are ad billboards literally everywhere and people you don't know write everything that happens down so they can figure out how to sell it to someone else.
Not if you use "FB Lite" app (no/NO ads, nothing but what you/YOU choose to see and open or not).thesameguy wrote: ↑Thu Nov 21, 2019 6:45 pmFTFY!Ed Lijewski wrote: ↑Thu Nov 21, 2019 6:33 pmMCA FB is the array of Forum topics plus even more but like Carlisle parking lot open-ended bench racing sessions where there are ad billboards literally everywhere and people you don't know write everything that happens down so they can figure out how to sell it to someone else.
Believe whatever it is you gotta believe.
They are giving you a platform, you are definitely giving them something back.
As Billy Shakespeare reportedly observed, "Yon thesameguy doth protest too much..."
Maybe.
I put it up in the air this morning and, well, it's all inconclusive.
With the car running in 1st and 5th there is zero noise from the transmission or from the driveshaft u-joints. Total silence.
I notice there is a distinct wobble to the driveshaft, but putting the dial gauge on it all the deflection is ON the driveshaft. The yoke and diff flange are perfect, but there is a distinct arc to the driveshaft. It's a Ford aluminum part, and I find it hard to believe an XR4Ti could bend the thing. But at the same time I have no recollection of what it was like when I installed it a decade ago.
I don't see any interference on the driveshaft itself. The e-brake cable and brackets are REAL TIGHT, but they've been that way since I installed everything, and there's no evidence of contact on the parts or the driveshaft itself.
The diff is silent. There is some slop between pinion and ring gear - I can rotate the driveshaft maybe 15 degrees or so before it picks up. I don't see an actual issue there.
The only place I am getting noise during this test is the half shafts.... all four CVs are making a racket in 5th. They're silent in 1st, but once they get moving they are literally rattling.
I think the next step is to replace those half shafts. It's not huge work assuming the bolts cooperate... they have been out before though I cannot for the life of me remember why. But those parts have been on the car for a long long time, so I don't feel bad about replacing them. The noise is road-speed dependent, it doesn't change from gear to gear, so that could be a match.
Seems like there aren't any options for half shafts.... Surtrack from RockAuto is it. Anybody have any experience there?
Edit: Autozone sells "Duralast Gold" axles, but they use the same imagery as rockauto's SurTrack and are 30% more expensive, although you do get a lifetime warranty down the street. The price difference is $50 total... maybe worth it?
Edit2: Autozone has free shipping and 20% off orders over $100 this weekend, so the cost end up within $5 of RockAuto. I pulled the trigger. Now to go soak my torx bolts in penetrating oil.
Took 10 minutes to get the axles off.
Three of the four joints are a bit bindy, one of the cups has a couple divots. Grease was present, but pretty dried up.
I'm reasonably certain they are not the source of the noise, but I don't mind replacing them. While I wait for the replacements to show up, I think I'm going to yank the driveshaft and take it to a shop for inspection. Maybe also see about hunting down another transmission, or maybe having mine rebuilt.
Also, it's becoming VERY difficult to find 4cyl transmissions.
So either a V8 transmission with a turned down input shaft that's 1/4" short
Or a '94+ transmission, with a turned down input shaft, and an MD-401-2110 adapter for the bellhousing, and modify the driveshaft or its adapter to get back the ~11/16" the bellhousing adapter uses
Or find someone to rebuild mine... which for a number of reasons I'm not prepared to deal with right now.
