Tires rubbing
Tires rubbing
Getting ready to drive the XR again, and the last couple times I had her out, I noticed wierd sounds when the steering wheel was cranked thru turns. Apparently my front tires are rubbing on the inner fenders, again. I have Hypercoil front springs from MC2(have to find receipt to remember what I have) but they are rubbing, I can see the paint has been removed by the tires. I am running 195-60-15 on Scorpio wheels. I can't remember if I'm using Scorpio front control arms or not, will have to measure and check. I also will double check ride height, but I seem to recall being at stock height as measured to the top of wheel arch from center of wheel.
What else could be causing this issue, if not ride height? I really don't wanna take the struts apart to add a spacer, though I seem to have spacers made of delrin ready to go in. Though they could be for the rear, its' been too long since I made them :roll: And the rear is another topic, as I have -3° camber on the drivers side right now...
Re: Tires rubbing
Dou have outer tie rod ends with the "angle" tip to limit turn-in before tires hit metal?
Re: Tires rubbing
I dunno, what do they look like? Is that the little "wing"? Will that affect turning radius?
Re: Tires rubbing
Yes, those. The wing limits the wheel arc.
This subject was discussed in a post here not long ago with some suggestions to try. Do a search.
Re: Tires rubbing
Will do, I actually think I have 1 or more laying around that look like that. Dunno if they're any good.
Re: Tires rubbing
No wings on the outer tie rods that are on the car. I did notice today on the way home from work what sounded like tires rubbing on the inner fenders thru one curve, and it wasn't even near full lock.
Maybe there's something else going on?
Re: Tires rubbing
Original fender liners?
Peeps use ~'90s Mustang fender liners which fit okay with some heat gun stretching, but maybe not always as well as OEMs in areas where tires can contact inner fenders.
[attachment=0]Screenshot_20210928-185446_Chrome.jpg[/attachment]
GPz11
Re: Tires rubbing
Post by GPz11 »
If the wheels are sticking out past the fender, you probably have Scorpio lower control arms.
In a weird coincidence, I had a XR LCA on one side and a Scorpio on the other. The Scorpio one stuck out farther.
Re: Tires rubbing
Ed, fender liners disintegrated years ago, this is tire on painted surface.
Gpz, when I look at the inner fender it appears as if the tires are rubbing on the inboard side of the tire, not the outer fender where rolling it might help. I will measure this weekend to see it I have Scorpio arms up front, but I don't think I do, of course I'm getting old, and the arms that are there were put in 6-7 yrs ago. I know I'm running the Scorpio front bar, it was hell to install.
Is the hole pattern in the subframe wider on Scorpio front subframe where the arms bolt in? I did change my front subframe out cuz the original was bowed significantly. Can't remember if the one I used came from a Scorpio, or an XR.
