Manual Shift Knob repair
talldiver
Post by talldiver »
I inherited a 1988 XR that had been in storage for 20yrs. Part of the laundry list of things needing attention is the shift knob. It is loose and when fully tightened, it faces 45 degree's to the right, towards the glove box.
Does anyone have any suggestions on how to fix this? I've tried washers and shims but they either look like crap or didn't work.
I'd like to keep it as much as how my buddy had it as possible but understand I might have to replace the knob.
I'm open to all suggestions and hope to have it ready for Carlisle next year.
Thanks.
Re: Manual Shift Knob repair
You could install this one
https://www.ebay.com/itm/195105607737
Or try to pull yours apart and epoxy it together how you like.
Wind a length of Teflon tape over the shaft threads.
talldiver wrote: Sat Jun 11, 2022 11:18 am
Don't beat yourself up thinking the car has to be perfect to go to Carlisle.
Some that show up, you'd wonder how they managed to drive them 300-500 or more miles without falling apart more on the ride. :)
talldiver
Post by talldiver »
andyofcolumbusmerkur wrote: Sun Jun 12, 2022 7:08 am You could install this one
Thanks for the info. That will be the last resort.
talldiver
Post by talldiver »
my8950 wrote: Mon Jun 13, 2022 10:02 am
I agree. I just need to get it past the state inspection. Currently working on the rocker cover gasket replacement. Then the rack/pinon boots and tie rod ends are replaced followed by rear disc conversion as the drums are seized and the parking brake doesn't work. Replace all the fluids and should be ready to rock.
talldiver wrote: Tue Jun 14, 2022 7:24 am
Nice!
If you don't already know, best valve cover gasket to use is the Ford part for the Ranger, they have the metal ring in them. Seems the FelPro and other floppy gaskets leak and can cause fires.
talldiver
Post by talldiver »
Nice!
I currently have a MAHLE gasket that has the metal washers embedded around the bolt holes.
talldiver wrote: Thu Jun 16, 2022 9:58 am
Nice!
If you decide to use that, carry a fire extinguisher or 3 at the least. That is same as the felpro and leak prone.
petenhxr4ti895spd
Post by petenhxr4ti895spd »
talldiver wrote: Sat Jun 11, 2022 11:18 am I inherited a 1988 XR that had been in storage for 20yrs. Part of the laundry list of things needing attention is the shift knob. It is loose and when fully tightened, it faces 45 degree's to the right, towards the glove box.
Thanks.
I just use red lock tight on the threads.
I was thinking the center of the knob was loose. That's why I said get some epoxy. But if that center section is in tight and it is an issue with the threads then I like the suggestions above. I like the one piece aluminum one that doesn't matter which way it faces since it is round. :D
Red? When Blue Loctite might itself be overkill unless nothing less worked?
I bet that is why my leather knob came apart the way it did. Had red locktite or super glue on there. A drop of the blue should be enough.
talldiver
Post by talldiver »
my8950 wrote: Fri Jun 17, 2022 12:40 pm
Nice!
ok. Is this the correct part # F57Z-6584-A?
talldiver
Post by talldiver »
Ed Lijewski wrote: Sun Jun 12, 2022 7:36 am Wind a length of Teflon tape over the shaft threads.
Teflon tape didn't work. Too thin. A little electrical tape worked like a charm.
