Front PBR Upgrade, Rear Disc Conversion, TBird MC Conversion
Post by thesameguy » Sun Jan 22, 2006 1:59 am
I totally maxed out the subject line! :D
I did my PBR upgrade months ago, but discovered shortly thereafter a leak in my master cylinder. I decided I might as well go ahead with the rear disc conversion, and since that meant a huge increase in brake piston volume that I should do DG's tbird master cylinder upgrade too.
There was holdup after holdup, but it's finally done!
I bled the brake system tonight pretty uneventfully. Once that was done, I was really worried about actually testing it. We had a blast making brake lines for my friend's '86 SPG - tons of leaks, bad flares, etc. This time I had a massive hydraulic flaring tool which it turns out isn't all that great, but it made far more reliable flares than the vice-mounted tool we'd used before.
Anyway, pumped the pedal a few times to build up pressure, then stood on it. It held firmly, no sinking. A quick visual under the hood and no leaks, so that's a plus. I need a helper to verify all is good since I can't stand on the pedal and check for leaks at the same time, but I'd say initial results are positive!
This is my reworked brake force distribution center. :D
This is my rerouted brake line to the passenger side. Previously, the line went about halfway up the false bulkhead, at the level of the top of the block deck. That was NOT fun to get out of the car, so when I redesigned the brake lines I routed them much higher, and stuck in a coupler to facilitate future removal/reinstallation. I doubt I'll ever need to pull it apart again, and honestly I wish there wasn't a coupler, but it was the easiest way to put it all back together, and I wasn't 100% confident my flares would work. :D
Finally, here is the passenger side of the line. The line used to run along at the height of that frame rail, right behind the exhaust elbow off the turbo. I hope a side benefit of rerunning this line is a little more distance between it and the exhaust, which may help keep the fluid slightly cooler. I doubt it, but it's a nice thought. :D
I resused what 4mm brake line I could, the rest of it is from NAPA. All the fittings came from http://www.fedhillusa.com - they were a pleasure to deal with, and one of the few places that not only catalogged bubble flare stuff, but also stocked it! Yes, I could have switched to inverted flares or something, but my goal was to retain as much of the stock setup as possible, and ensure compatibility with Mike's stainless lines. The flaring tool is a hydraulic MasterCool universal kit. $300 - it worked, but I think there may be better tools out there for not much more. In its favor it does ALL the flares out of the box, including the push connect fuel lines, so maybe that'll come in handy some day. I'm debating on re-bay-ing it and buying the flaring tool than Fed Hill sells... although, really, I don't expect I will ever have to flare anything ever again! :D
With any luck tomorrow I can put the new ported manifolds on and get to finding all sorts of fluid leaks. It appears I've got at least a p/s leak and a coolant leak, and possibly an oil leak from the cam area. I think I've already solved the last one, but I won't know til she's running again. What fun! :D
Specktor
Post by Specktor » Mon Jan 23, 2006 2:49 am
Just a comment but with the brake line that close to the turbo you will be heating up the brake fluid in the line which can cause problems ,I would suggest putting a heat shield of some sort between them.
88 maroon xr4ti,
88 xr4ti now blue.
88 xr4ti black,
88 xr4ti red,
88 xr4ti white.
Can I stop now I'm broke.
Post by thesameguy » Mon Jan 23, 2006 3:18 am
Specktor wrote:Just a comment but with the brake line that close to the turbo you will be heating up the brake fluid in the line which can cause problems ,I would suggest putting a heat shield of some sort between them.
It was closer to the turbo to start with. Take a look at the space between the stock brake lines and the turbo elbow. I actually gained a couple cm of clearance in the move...
Mike McCreight
Post by Mike McCreight » Mon Jan 23, 2006 10:37 am
Nice work... I live in fear of having to replace lines on my wintermobile... Bubble flares..... :?
xrian
Re: ?
Post by xrian » Mon Jan 23, 2006 12:59 pm
Mike McCreight wrote:Nice work... I live in fear of having to replace lines on my wintermobile... Bubble flares..... :?
Ian G-J
Ontario, Canada
Mike McCreight
Post by Mike McCreight » Mon Jan 23, 2006 3:04 pm
Sens, 7 Leafs, 0. :lol:
Re: ?
Post by thesameguy » Mon Jan 23, 2006 5:24 pm
Tell me about it. What a PITA. The only reason I had the courage to do all this was because my friend installed a booster-less master cylinder and enormous Wilwoods on his SPG. I had the chance to live through the hell of redoing his lines first...
I ended up buying this badass MasterCool hydraulic flaring thing, which knocked out bubble flares like nobody's business. I only blew two amongst the 10-20 practice flares and ~12 installed ones. The only untouched line in the car is the one from rear brakes to the front of the car. Everything else is 100% KUSTOM!!!!
Of course, it has yet to be seen whether they hold, but I have high hopes... :)
Re: ?
Post by DPDISXR4Ti » Mon Jan 23, 2006 5:43 pm
Mike McCreight wrote:Sens, 7 Leafs, 0. :lol:
That's gonna leaf a mark! :twisted: :lol:
xrian
Post by xrian » Mon Jan 23, 2006 5:50 pm
Hell, that doesn't even surprise me anymore! The Loaf's will probably loose again tonight. That's why I'll watch 24 instead.
Ian G-J
Ontario, Canada
