- Tremec TKX, QuickTime V8 Bell
- tkxwithbell.jpg (133.75 KiB) Viewed 217 times
Just got a '86 Merkur
Re: Just got a '86 Merkur
Another setback, I just discovered today that a Hays 82-103 hydraulic throwout bearing is not compatible with a Spec SF481 clutch
The Hays bearing has a sleeve that goes past the pressure plate fingers and it can't on the Spec.
Anyone need a Hays 82-103, hit me up.
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
I have another issue, the QuickTime bellhousing contacts the stabilizer bar, I was hoping once tranny angle was adjusted it'd be ok, but no,
the bellhousing is not putting much pressure on the stabilizer.
I'm certain I can add a spacer behind the stabilizer U brackets, likely .125" would be sufficient, but I'm wondering how much this might throw off the front alignment? I think this would move the front wheels forward about .06".
I guess I could revert back to the original stabilizer, that might be enough, or not worry about it and drive it like it is, I'm sure it won't hurt anything, maybe just rattle occasionally.
- Attachments
- stabilizerbellcontact.jpg (158.5 KiB) Viewed 8 times
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
