- Tremec TKX, QuickTime V8 Bell
- tkxwithbell.jpg (133.75 KiB) Viewed 9965 times
Just got a '86 Merkur
Re: Just got a '86 Merkur
Another setback, I just discovered today that a Hays 82-103 hydraulic throwout bearing is not compatible with a Spec SF481 clutch
The Hays bearing has a sleeve that goes past the pressure plate fingers and it can't on the Spec.
Anyone need a Hays 82-103, hit me up.
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
I have another issue, the QuickTime bellhousing contacts the stabilizer bar, I was hoping once tranny angle was adjusted it'd be ok, but no,
the bellhousing is not putting much pressure on the stabilizer.
I'm certain I can add a spacer behind the stabilizer U brackets, likely .125" would be sufficient, but I'm wondering how much this might throw off the front alignment? I think this would move the front wheels forward about .06".
I guess I could revert back to the original stabilizer, that might be enough, or not worry about it and drive it like it is, I'm sure it won't hurt anything, maybe just rattle occasionally.
- stabilizerbellcontact.jpg (158.5 KiB) Viewed 9756 times
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
Are those the thicker Cosworth sway bars? What about putting a relief in the bellhousing for some clearance? Doesn't seem like you'd need much.
They are Rapido 28.5mm, I guess going stock would only gain a little over 1 mm additional clearance.
I'd hate to grind into the new bellhousing, but an idea, I think the bellhousing wall thickness is .125" or a bit less.
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
Just thought of a easier solution... I can raise the engine and tranny! I'm gonna try this
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
I needed to get the input shaft out to have it turned down, complete disassembly is required! Wasn't too bad, I'd do it again, it was nice that it was brand new though
- This is what a new Tremec TKX looks like
- tkxdisassembled.jpg (312.58 KiB) Viewed 8961 times
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
Have a '86 Merkur XR
I think I'm done with the Auto Meter dash mod, I think it looks pretty good.
I designed all the parts needed to install the gauges with no screws or glue needed,
you just need to do some cutting on the dash to make room for the gauges and idiot lights, I used a dremel.
Once assembled you can't see any cuts.
- XR4TI dash rear view
- rearview.jpg (353 KiB) Viewed 4975 times
- XR4TI dash front showing cuts... not pretty but doesn't need to be.
- cutupdash1.jpg (341.97 KiB) Viewed 4975 times
- XR4TI dash modified with autometer gauges
- frontview.jpg (340.97 KiB) Viewed 4975 times
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
I have got a '86 Merkur XR4TI
Here's a pic of the parts needed, I'll upload them to Thingiverse.
You may have noticed I spaced the 2 upper small gauges out,
I did this to help fit the gauges closer together, so the lower gauge is less buried.
I haven't actually tried to fit this in the car yet, but I'm sure it will.
I got the idiot lights off Ebay.
- XR4TI right side gauge cluster
- rightside.jpg (358.84 KiB) Viewed 4975 times
- XR4TI 3D printed parts
- allparts.jpg (475.27 KiB) Viewed 4975 times
- XR4TI rear view showing grinding
- cutupdash2.jpg (337.11 KiB) Viewed 4975 times
'86 Merkur XR4TI
'05 SRT-4
'08 Hemi Ram
'05 SRT-4
'08 Hemi Ram
Super awesome. Nice job, Fully impressed and can can fully relate.
I uploaded this to thingiverse in October..
https://www.thingiverse.com/thing:6303111
3d are printers awesome?
FWIW, Look at my link, Notice the 2d bar code and request for a tip.
Set yourself up with a paypal tip page. You'd be surprised. It's not overwhelming but it is nice once in a while when folks tip you from time to time.
The way I look at it is I'm doing this for myself regardless for my own restorations. I'll post it for others and if they can benefit then maybe they can contribute.
Also it is important to make sure folks look at you other models on thingiverse, so make a url easily available that points to your other models on thingiverse.
Naturally, if there are those interested to ask you here on this forum through private messaging if you can print them set then consider your effort and time accordingly and set your price accordingly.
I think I sold three sets of my rear suspension rebounds to fellow forum Scorpio members. Heck it's a limited market! But it helped me and it helped them.
So...In the end you are helping everybody in this hobby.
Rear suspension rebound cone purchaser/installer here
