Junkyard Shopping List - Feel free to contribute
85xr
Post by 85xr » Wed Sep 01, 2010 4:50 pm
was looking today at a 93-94 ranger that had the round tooth timing gears. had the 2.3, so im guessing they should fit?
greg
Post by DPDISXR4Ti » Wed Sep 01, 2010 6:20 pm
85xr wrote:was looking today at a 93-94 ranger that had the round tooth timing gears. had the 2.3, so im guessing they should fit?
Yes, '92 - '93 Mustangs and '92 - '01 Rangers will have the round tooth sprockets.
Post by merkurdriver » Mon Jan 10, 2011 5:18 pm
BIG VAM donor vehicle list:
1984-1986 Mustang SVO
1987-1988 Thunderbird Turbo Coupe
1985-1993 BMW 535i
1985-1989 BMW 635csi
1985-1992 BMW 735i
1988-1992 BMW 735il
1987 BMW L6
1986-1987 BMW L7
coupelx
Post by coupelx » Mon Jan 10, 2011 7:28 pm
I am running sprockets off a 92 mustang and they are most definately square.
1987 Xr4ti
Re: Junkyard Shopping List - Feel free to contribute
Post by DPDISXR4Ti » Tue Jan 24, 2012 12:35 am
1991 - 2001 Ford Explorer (1st and 2nd gen) - Rear shocks (minimal mods required - search for more details)
2000 - '05 Focus - Front struts (strut tower re-fabrication required - search for more details)
Post by DPDISXR4Ti » Sat Apr 06, 2013 9:26 am
~1990 ('88 - '94?) Chevrolet Cavalier - 12v+ power distribution mounting terminal w/ in-line fuse on orange wire circuit. Located on false-firewall - 7mm socket required for removal.
Post by hEaT » Mon May 27, 2013 11:35 am
Not a junkyard part per say, but for those with the stock or shorty radiator, the lower hose from a 1992 - 2001 Toyota Camry works great as an upper hose replacement. Got mine from Advance Auto for $20, in stock, no fuss. Part number is DAYCO 71679.
I trimmed what you can see there off the thermostat end. For a stock radiator, you'll need to take some off the radiator end too. The extra length there is what you need for Mike's short setup.
thommi7
Post by thommi7 » Wed Jan 29, 2014 8:29 pm
Time to wake this thread up!
Air-Oil cooler from a police cruiser. Search for details.
Wastegate actuator from Saab turbos. Adjustable ;-)
Post by DPDISXR4Ti » Fri Jan 01, 2016 7:31 pm
Some new additions to welcome in 2016...
Circa 2000 Volvo S80
- Trunk-mounted battery stuff - Nice heavy-duty + and - cables. Nearby attached 12V+ power distribution box w/ four 40A fuses
'03 - 11 Saab 9-3 Turbo
- Top air-charge hose - 2.75" w/ 90-degree elbow to 2" - Saab p/n 12785081 (Might be useful when using NPR Intercooler)
Post by DPDISXR4Ti » Sun Feb 21, 2016 11:03 pm
1st Gen Toyota MR2 ('84 - '89) - Inline Coolant Filler fitting
2nd Gen Toyota MR2 ('91 - '95) - Electric Power Steering (search for details)
Post by DPDISXR4Ti » Sat Jan 07, 2017 10:43 am
Starting off 2017 with a small addition to this thread...
~'95 - 2004 Land Rover V8 Exhaust manifold bolts. They measure 50mm vs. 52mm for stock 2.3T bolts, so close enough. The head is a 12-point, 12mm, so much smaller that the stock 6-point, 17mm. This might make them useful for some headers where clearance is a challenge. They also come with spacers which could be used as-is or machined in some way.
Post by DPDISXR4Ti » Thu Mar 02, 2017 12:59 pm
Volkswagon Front struts (search for details)
1998-2008 VW Beetle
1999-2005 VW GOLF IV
1999-2005 VW Jetta IV
Post by DPDISXR4Ti » Thu Nov 07, 2019 5:52 pm
It's been awhile, but here's a small addition for when you're looking for new wheels studs just a little longer than stock and have only 30 minutes until closing time at the junkyard and need to come home with something. I only removed them from the rears as they are much easier/quicker to harvest....
2012+ Focus & Escape 12mm x 47mm
2011+ Fiesta 12mm x 45mm
20?? Fusion 12mm x 42mm
Stock length is 40mm for both XR & Scorpio. The spline diameter seems to be around 12.85mm
