Torque Spec for Lugnuts
moetzmoet
Post by moetzmoet »
Hi all. I have a shop manual and noticed that I see two different torque specifications listed for the lugnuts and was wondering which one was correct. Please note, I am not looking at the nM and ft/lbs and finding the difference...it is in the ft/lbs in each instance. In the section itself, they state 50-70 ft/lbs a couple of times, but at the end of the section, under torque specs, I see 75-100 ft/lbs.
Any help finding the correct specs will be greatly appreciated! Thanks!
Re: Torque Spec for Lugnuts
Post by hEaT »
I believe 75ft/lbs is what we've universally agreed on for stock lugs on stock wheels.
http://www.mc2racing.com/tech/TorqueSpecs.pdf
Stock lugs are 45* conical seat. When using more common 60* conical seat lugs on aftermarket wheels, I use 95-100 ft/lbs, especially with ARP studs.
Joe
1985 Nimbus Grey XR
2002 SVT Focus
2017 Ford Focus RS
