Driveshaft pics XR T9, XR C3, Scorpio A4LD, Scorpio T9
Driveshaft pics XR T9, XR C3, Scorpio A4LD, Scorpio T9.
I sent these to anglin for the MTPP submission, but I thought a quick post up would be good to do as well. This is all 4 different Merkur driveshafts lined up.
Funny how the XR t9 driveshaft is shorter than the XR c3, yet the scorpio T9 driveshaft is longer than the A4LD.
-Ray
1985 Ford F150 - Tow Missile
2005 Subaru LGT
http://www.cartct.com
2005 Subaru LGT
By the data Mike's provided, you should be able to calculate how much length was added to the tail-housing to make the C3 into a A4LD. I come up with 4.625"demonfire wrote:Funny how the XR t9 driveshaft is shorter than the XR c3, yet the scorpio T9 driveshaft is longer than the A4LD.
Good pic Mike.
You mean to the front of the trans case for the OD unit But you were just checkin' to see if I knew thatDPDISXR4Ti wrote:By the data Mike's provided, you should be able to calculate how much length was added to the tail-housing to make the C3 into a A4LD. I come up with 4.625"demonfire wrote:Funny how the XR t9 driveshaft is shorter than the XR c3, yet the scorpio T9 driveshaft is longer than the A4LD.
Good pic Mike.
Any reason why this shouldn't get moved to the FAQ directory?
www.mc2racing.com
www.mc2racing.com
Re: Driveshaft pics XR T9, XR C3, Scorpio A4LD, Scorpio T9
Bumping, as I've just moved this to the FAQ....
Reposting the pic since the whole photobucket thing has blurred the original image...
- driveshafts3.jpg (68.59 KiB) Viewed 13445 times
Is there an example of the driveshaft with U-joints instead of the center support bearing and guibo that could be added to the mix? I think since there are numerous ways to convert to T5, or simply swap the swap out to get rid of the guibo, it would be helpful in the next 10 years. I'm saying that because I realize this photo was originally posted in 2010.merkurdriver wrote: ↑Fri Nov 22, 2019 4:22 am Reposting the pic since the whole photobucket thing has blurred the original image...
It would help me to see one like that though, with u-joints instead of guibo. I understand driveshaft, but U-joints & 1310 and all that crap I do not.
Those are all stock driveshafts pictured. All stock driveshafts have the guibo, center support bearing, and staked in joints.
There are indeed numerous ways to stick a T5 in.
Here's milehighXR's image of a stock driveshaft (bottom) vs. one thats been modified for a T5 install:
Center support bearing is still there per usual, but the guibo has been removed and a common yoke welded in its place. Once that yoke is there, you can use off the shelf 1310 u joint to attach an off the shelf T5 slip yoke. Bolt it in and done.
Next T5 option is to use a driveshaft flange adapter from Merkur Midwest:
This bolts to the differential flange and changes the bolt pattern - this will allow you to bolt in a fox body Mustang T5 driveshaft into an XR.
This route also opens up the option to bolt in a M-4602-G Ford Motorsport Aluminum driveshaft also:
Ok, thanks for that...Seems like the one piece V two piece is a controversial topic for vibration & stuff.
I also heard that the aluminum D/S for the Fox is too big of diameter when installed in the XR, it hits the E-Brake cable mount, or something in that area.
We all have our own bastard combo that we're trying to do.
My plan is a 93 V8 T5 from a Mustang, not sure yet on D/S, and Supra diff...
Yes, the big diameter alum DS will (initially) hit the little e brake tabs...but that's pretty easily rectified by bending or cutting the edge of the tab for clearance. Having done both multiple times (steel Mustang DS as well), I really like the custom 2 piece route like in the pic above.
That being said, if you plan a Supra diff install down the road then you will have an easier time sticking a (new) diff flange on the Mustang DS vs. the XR DS.
Gotcha, so based on what you say here, maybe my best bet is a one piece with the correct flanges? I guess I just wonder about the balancing of the one piece as it seems many people who go this route complain about vibration that doesn't seem to go away.merkurdriver wrote: ↑Thu Nov 28, 2019 3:44 amYes, the big diameter alum DS will (initially) hit the little e brake tabs...but that's pretty easily rectified by bending or cutting the edge of the tab for clearance. Having done both multiple times (steel Mustang DS as well), I really like the custom 2 piece route like in the pic above.
