XR vs. Scorpio Inner Tie Rods
Scorpio and XR4Ti steering racks are identical besides one detail... the inner tie rods.
Here is a picture showing the XR inner rod (top) and Scorpio inner rod (bottom).
More than once has someone went to put a reman'ed rack in their XR to find out the tie rods are too long because they've been given a "Scorpio" rack. And the parts slingers on ebay (and elsewhere)
all seem to list the same tie rod for both cars. You do not want XR inner tie rods on your Scorpio, its pretty dangerous!
Might be worth a move to the FAQ?
Re: XR vs. Scorpio Inner Tie Rods
But...as Scorp inners are NLA, is there enough threaded length on XR inners for them to work installed on a Scorp (iffy but maybe possible?).
That is precisely why Mike said... "You do not want XR inner tie rods on your Scorpio, its pretty dangerous!"Ed Lijewski wrote: ↑Sun May 26, 2019 3:26 pm But...as Scorp inners are NLA, is there enough threaded length on XR inners for them to work installed on a Scorp (iffy but maybe possible?).
Maybe if you want a whole bunch of toe-in it might be safe enough? Not that there would be a sensible reason for that.
- Power Tryp
Since you have those out any chance you could verify the thread pitch and diameter on those? I've been looking at some drift spec tie rods from Australia but they may end up being the cockford-ollie for the you Scorpio guys who can't buy factory fresh.
https://www.enjukuracing.com/products/g ... ually.html
Ford Parts Geek.
87 XR4TI
80 924 Turbo
87 XR4TI
80 924 Turbo
I think this was just recently moved to the FAQ. My original post date shown is from 2012, so I don't have these sitting in front of me to measure right now. However, fast forward 7 years and I have new inner and outer tie rods available for the Scorpio ( and XR4Ti ).
- Power Tryp
Damnit Ed, digging up old posts...
Mike, would you happen to know if the threads on the Scorp and XR4Ti an M14?
Ford Parts Geek.
87 XR4TI
80 924 Turbo
87 XR4TI
80 924 Turbo
Ed, don't know where you got the idea that they are NLA. I just picked up a couple sets of Scorpio ones, brand new, from Russ at Rapido. Should look for some XR ones for one of these 2 racks I need to clean up and rebuild.
Tim Spencer
M14x2,0 outer and M14x1,5 innerPower Tryp wrote: ↑Fri Jun 07, 2019 11:39 am Damnit Ed, digging up old posts...
Tim Spencer
- Power Tryp
Thank you for that.timxr8 wrote: ↑Mon Jun 10, 2019 8:07 pmM14x2,0 outer and M14x1,5 innerPower Tryp wrote: ↑Fri Jun 07, 2019 11:39 am Damnit Ed, digging up old posts...
Ford Parts Geek.
87 XR4TI
80 924 Turbo
87 XR4TI
80 924 Turbo
FYI If anyone is looking for Scorpio inners...
NEW Scorpio Inner Tie Rods:
https://www.ebay.com/itm/NEW-1988-1989- ... 2729991957
