rack rebuilding or replacing?
- Level 4
Searching shows a discussion about rebuilding XR racks ourselves, but I see no conclusion posts. So is this what people are doing these days?
I noticed Rockauto carries a kit for the ZF (waffle) rack for $30, anybody tried it?
also pskits.com list kits for either ZF or TRW ($48 vs. $25)
Any advice here?
Mine is the ZF (waffle) rack and is leaking on both sides, no loose steering or tie rod issues.
thanks
James
Any advice here?
thanks
James
Cossy sway bar, Powerflex, Dynalites, Focus SVT rotors,Koni yellow sleeve over 8"x300lb/in springs,Scorch bumper cover, 17x7.5x40mm Binno wheels, 225/45-17 Kumho 712 tires
- Level 1
Re: rack rebuilding or replacing?
Having recently messed around with mine, I tried doing the 'depowering' mod described in one of the threads (can find it by searching here) and ran into an issue. The thread describes the procedure for a trw rack, not a zf. While the process was similar, there was definitely some major differences. I ended up not being able to even remove my rack from the sleeve. I will definetly be doing more research before I try and tackle a rebuild or depower again. Hopefully someone here will be able to provide a better step by step with pictures for the zf rack. Conceptually it is not difficult though. I ended up finding a rebuilt rack that I will be swapping in instead. Good luck though if you do decide to rebuild and hopefully you'll remember to take pictures of the process unlike me
- nathankershaw
I used a PSKIT last time and am about to again.
Fairly simple, it was the more expensive one.
I had a very slight leak where the steering shaft goes in after but nothing to worry about, I did one inner track rod arm as well.
All good. Just take your time.
It worked well for me.
I've done 4 pskits.com ZF kits with great results. Just be super clean!
While you are at it, redo the pump as well. $12 kit from any auto store.
XR and Scorpio blower motor rebuilding, LED upgrades, XR lock service
I am going to try and rebuild my ZF rack I ordered the PSKIT we shall see how it goes. I did fid some information that might help. http://forum.bmwland.ru/index.php?act=a ... t&id=26966
Rob
88 XR4Ti Stock, Daily Driver
88 XR4Ti Lightly Modified.
- Level 4
cool, post any tricks or tips that you figure out, I'll try and take a few pics while I'm doing mine. My kit should arrive sometime this week.
cheers
James
cheers
James
- Level 4
got the kit from skits.com today, the receipt says SK-8449 but the packages reads SK-9120 1983-92 Volvo 940/960 or Scorpio with ZF rack 1988-1990 so I guess it's the right one.
Does anyone know if the Volvo rack is compatible with our cars? Might be easier to get.
Here's a few pics of what I got
hope those links work
JAmes
JAmes
- nathankershaw
Yeah I think Scorpio & XR ZF racks are the same.
Yep that is the same kit I received the receipt also in hand writing sk-8449 I'm guessing we will soon find out
Rob
- Level 4
Anybody know if there are any bearings that need to be replaced? If so what size are they?
Bearings should be fine unless you know you sandblasted them or something horrible. I've never replaced mine. Just clean up and re-pack. Smooth as silk, or rayon perhaps......
I need to do this sometime as well, I have a slight hard spot on center. I think it might be that shuttle valve but I want to rebuild the seals while i'm at it.
Jeremy Kemp
IT is on my list as well. I have a notchiness when moving the wheel, so I imagine the rack is in need of repair or restoration.jkxr4ti wrote:I need to do this sometime as well, I have a slight hard spot on center. I think it might be that shuttle valve but I want to rebuild the seals while i'm at it.
David Reese
- Level 4
what cures the notchiness? Are these parts available? I assume it's just a bearing issue?
