Front Brake Rotors...Do any other ford rotors fit?
Izzy
Post by Izzy »
Just wanted to know if the thunderbird or mustang front rotors fit on and what year... thanks!!
Eric
janvanv
Re: Front Brake Rotors...Do any other ford rotors fit?
Post by janvanv »
Izzy wrote:Just wanted to know if the thunderbird or mustang front rotors fit on and what year... thanks!!
Eric
Yeah lots will fit like the 2wd Cossie, and the 4wd Cossie and the SVT Fucus, they all fit perfectly.
But then the calipers won't fit..
Whaddya trying to do??
John Vanlandingham
JVAB Imports
Seattle, WA, USA
Izzy
Post by Izzy »
Hey John, i know ya from SS.com :P I was thinking of emailing you and asking you since ur the Guru.
Well the parts store wanted like 85$ a rotor, and i heard thunderbird ones fit and there cheaper. But ya caliper fitment problems
i guess would happen, guess ill just buy the merkur ones.
janvanv
Post by janvanv »
Izzy wrote:Hey John, i know ya from SS.com :P I was thinking of emailing you and asking you since ur the Guru.
I sent you a PM today cause you never came down, what's the que paso on the build deal??
I have just done a run of 28 aluminum hats or bells so we CAN do big herking 1 1/4" thick, 283mm diameter discs and alloy 4 pots directly onto the Xratty front spindle, and if'n you'd come and visit you could BORROW front rotors till you could do the upgrade..
And all joking aside, there ain't an easy diddle.
And the Tbird rears are way small, not worth the bother...
I'd upload some piccies of the new stuff except "BC Boy Skye" set up some stoopid password I can't remember to the upload thing> and nobody has heard a peep for weeks from him.
John Vanlandingham
JVAB Imports
Seattle, WA, USA
anglin
Post by anglin »
Alrighty folks. This one has been asked enough times to get moved to the FAQ section. I just need to get input from folks as a sort of "peer review."
I'm of the belief that the Merkur XR4Ti has OEM front brake rotors unique to it and only it in North America. I'm also of the belief that the Merkur Scorpio has OEM front brake rotors unique to it and only it in North America. All of the PN evidence I have seen supports this claim. I've never seen any cross reference info on them.
Layman's terms... if you want front brake rotors for your Merkur, you're going to have to ask for front brake rotors for a Merkur.
Before I go posting my "opinion" to the FAQ section, I'd love to get folks "in the know" to acknowledge the accuracy of, or correct the errors in, my statement above.
www.mc2racing.com
Izzy wrote: Well the parts store wanted like 85$ a rotor,
:shock: What parts store was that? Around here (Ohio) we get stock XR front rotors for under $50 a rotor.
Colin
Post by Colin »
Holy crap, guys... I think I can get rotors at work for under $25 apiece. :lol:
Colin
Instagram @colinrdoyle
89 Scorpio 2300-16V // 07 F-650 Cummins // 00 Beetle TDI
File to fit, paint to match.
John Brennan
Post by John Brennan »
I got the nice dimpled and slotted EBC rotors from Phil for that price point (less, I believe, at the time). And yes, they do work very well.
WesP
Post by WesP »
Ok since we're on this topic, has anyone used the SVT Focus front brakes on an XR? I currently have Cosworth Escort 278mm rotors and single piston calipers (looks alot like the SVT Contour one) and wanted to upgrade to something larger and more readily available here. The XR caliper will bolt up to my Cosworth spindle so I'm hoping the upgrades are interchangeable.
1995 Escort RS Cosworth Lux
Maurice S
Post by Maurice S »
I THINK other (SVT, Cossie blah blah) rotors will actually fit but only work with corresponding caliper changes and brackets etc...the stock rotors are indeed unique unless one wants to make other changes..
85 XR '" Lightly Street Massaged"
janvanv
Post by janvanv »
WesP wrote:Ok since we're on this topic, has anyone used the SVT Focus front brakes on an XR? I currently have Cosworth Escort 278mm rotors and single piston calipers (looks alot like the SVT Contour one) and wanted to upgrade to something larger and more readily available here. The XR caliper will bolt up to my Cosworth spindle so I'm hoping the upgrades are interchangeable.
I've offered up the HUGE SVT FUCUS rotors to both 2wd Cos and 4wd Cossie knuckles and yeah the FIT center and studs but the centerline offset is screwy.
There are progressively deeper hats on Ford Sierra based discs w the deepest being 2wd Cos, then Xratty, then the much flatter 4wd Cos, SVT Contour, SVT Fucus.
The flatter hats bring caliper OUTBOARD wheel interfereance issues with them, doubly so when using nice 4 piston calipers.
Just what are you specifically trying to do with your brakes??
(it's very likely I've been trying to do something the same for about 8 years)
John Vanlandingham
JVAB Imports
Seattle, WA, USA
WesP
Post by WesP »
I have an XR with the Cosworth AWD setup including brakes and suspension. I want to upgrade the front brakes and at the same time get something that I can buy off the shelf here. The SVT Focus brakes seems to be the most logical and cost effective choice.
I compared the SVT Contour rotors with mine and the hats are the only difference, in fact when I needed front pads I ordered a set for a Contour.
What you got? :roll:
janvanv
Here's some brake porn
Post by janvanv »
Guys its 11.00 Pm and I've been fighting evil doer bureaucrats and I'm tired.
Here's more tantalizing piccies and I'll write tomorrow more when I get up.
These are so cool BooBoo Panda, the coolest cat in the wolrd had to come and look:
Here's Xratty and 2wd Cossie:
Here's 2wd Cossie, JVAB Gravel Spec, and stock Xratty:
Here's 2wd Cossie and 4wd Cossie (note the extreme shallow hat):
Now back side showing the ears tapped to M12 x 1.75:
Now with a Willwood Sperlite IIA:
And this is it for now:
More later, but folks, these are cheaper than you think.
it's all about how many I can afford to do at one time, there is very nearly
$20 of chips carved out of each hat.
John Vanlandingham
JVAB Imports
Seattle, WA, USA
babycheesmo
Post by babycheesmo »
audi 90 rotors fit perfectly, they are exactly the same!, i was changing pads and remembered i had brand new brembos for my old audi 90 and the were identical.
babycheesmo wrote:audi 90 rotors fit perfectly, they are exactly the same!, i was changing pads and remembered i had brand new brembos for my old audi 90 and the were identical.
Isn't the center-bore 57mm on those, same as the wheels?
