Themal limiting fuse - Blower Only Works on High Setting, XR
i decided to tackle my next problem.. my blower only works on one speed. so... i removed the module but my question is.. that little thing that looks like a capacitor is that the limiting fuse you guys say you have to replace ?? if so.. how the heck do you get it out.. mine is in there pretty tight im afraid im gonna break one of the springs on the module
89 Red XR,
mods- Probe FMIC, hood scoop, LA2, Big Vam, 2.5 Exh. CAI, pillar mounted boost & a/f gauges, MBC @ 15, dual-wing hatch, aftrmkt. Trans. cooler,tinted windows, mesh grille insert
" Second place is just the first loser "
Phil
Phil
- Mike McCreight
There's supposedly a cheap Radio shack capacitor/resistor? option available which you would need to unsolder and resolder maybe someone will chime in on that...also check out the merk encyclopedia I thingk they have a write up on ithttp://www.merkurencyclopedia.com/Merkur_misc/used%20XR.html .. BAT in FLA sells the whole module pg 41..if you wanna go that route
85 XR '" Lightly Street Massaged"
im working on trying to get the old fuse out... it broke off where it crimps so now im digging trying to get the darn thing out. ill get it
89 Red XR,
Phil
Phil
i went by my local radio shack and those guys didnt have a clue... does anyone happen to know the radio shack part number ??????
89 Red XR,
Phil
Phil
well... i did some more researching and i couldnt find the radio shack part number but i did find a part number that is supposdly common in the electronics industry and is suppose to be a direct replacement for our thermal limiting fuses....so if you guys need it here it is... im going to go pick it up from a electronics distributor here in my town..
NTE 8118
NTE 8118
89 Red XR,
Phil
Phil
- Mike McCreight
- John R. Rowlands
- John R. Rowlands
