Junkyard Shopping List - Feel free to contribute
Somebody once suggested that I should write up a list of items to get at the junkyard for your Merkur, that you might not otherwise think of. I figured I sure don't have all the answers, so this should be a "community effort". The idea here is to NOT include items from a Merkur - it should be obvious that items from a junked Merkur should fit another one. Let's NOT even cover here items that can be swapped between a Scorpio and XR - too many of those. Okay, I'll start it off...
'79 - '93 Saab 900 radiator with fan(s)
Pre '87 Ranger wheel studs (longer than stock)
'85 - '87-ish Nissan 300 ZX Turbo Compressor housing
'80's Mazda RX7 & Nissan sentra brake booster check valve (similar one found on '86 - '92 Toyota Supra)
'87 - '89 F150 or E150 (van) external fuel pump (p/n E7TF-9350-AA)
late 80's/early 90's 4-cyl Volvo heads (8V & 16v)
turbofan
Post by turbofan »
do you wanna list the obvious big vam and chip and stuff?
VAM and ECU from '87/'88 Thunderbird TurboCoupe or '86 SVO. (should be intercooled if you're going to use this combination!)
How about just random stuff that fits?
TC wheels (with slight modifications)
Tempo front springs (pull them out of a V6 model... slightly stiffer than stock XR springs)
do we dare even touch brakes?[/b]
Ed (yep, another Ed....)
THEY ALL (except partsie) RUN!
http://www.cardomain.com/id/turbofan
Frag
Post by Frag »
Ford 5.0L (or 3.8L) CFI fuel pressure regulator - Can be used as a stock replacement or turned into an adjustble fuel pressure regulator.
Ranger Roller camshaft - Can be found in Ranger as well as Mustang dual plug heads.
Pontiac Fiero - Manual rack can be used with modification
1993+ Ford Ranger valve cover gasket, has metal insert.
Gates part # 20459 / Dayco part # 70416 - Replacement Turbo outlet to Throttle body hose, requres cutting.
Ford Thunderbird - V6 motormounts, Work as replacement requires modification.
BMW Driveshaft guibo - Can be used on XR4Ti Part# 103-2103
Freejack
Post by Freejack »
Scorpio ABS - The Teves II system can be found on the TC, Lincoln Mk VII and some GM vehicles of the same vintage. The actual MC is a different arrangement on each car, but some parts interchange, such as pressure bulb or the pressure switch (note- connectors can vary).
Jake
jasonty
Post by jasonty »
some UPGRADE parts:
Mustang 99 GT era PBR front calipers
TBTC 87/88 rear calipers
TBSC master cyl
WC T5 Trans
87/88TBTC and 85-86 SVO E6
Contour 7 spoke 15in rims (ala Euro RS rims)
Ford 2.3 intakes
Sirraco(spell) radiator
jason yancey
stephens city va
87XR-88XR
NOVAMOG
"as long as you keep picking on me I will tend to mad post about me getting mad......"
Frag
Post by Frag »
4x108 Wheel list.
Alfa - Spider
Audi - 90, 100, 200
Ford - Focus, Contour, Tempo, Mustang '74-'93, Thunderbird '80-'88, Farimont '78-'86 Pinto '71-'80, Fiesta '78-'85, Escort, Cortina
Mercury - Mystique, Cougar, Topaz, Taurus, EXP, Lynx '80-'89, Zephyr '78-'86
Porsche - 924 '77-'84
Plymouth - Cricket
Saab - 99, 900, 9000
Sunbeam - Tiger - Alpine '65-'70
janvanv
DJ!!!!
Post by janvanv »
Frag wrote:4x108 Wheel list.
Saab - 96, 99, 900, 9000
[/b]
Wassamatta U?
Everybody knows the Saab 96 was5 on 170mm, sheesh!
and the 99 was 4 on 4 1/2"
and the 900 was UP THRU 87 was also 4 on 4 1/2"
The ones which work are Saab 9000 from 1985 on and possibly some versions 900 from 88 on.
And the ever popular Puegoet 205, 309, 206 etc.
John Vanlandingham
JVAB Imports
Seattle, WA, USA
Post by John Brennan »
Which of those has an offset that's gonna work? For example, the Pinto has an old-school, negative offset, doesn't it? Deffo grab the low-mount alt. bracket, though.
2.3T serpentine brackets, Ranger 2.5 blocks, SVO/TC/2.3 'Stang trannies, Capri driveshafts, not sure on the specs. There are lots of IC cores that are worth grabbing also, as we all know. 8.8 difs, BMW 5-series difs; lots of stuff.
Here's a couple items everybody should have as spares in their gloveboxs - first, it's the EEC Relay, attached to the bracket which is attached to the back side of the glove-box.
A '89 - 95 (MN12) 3.8 T-Bird/Cougar uses the same relay, though I'm not sure of it's use there. It can easily be found in the small relay box under the hood (driver's side, up front).
Second, is the fuel pump relay. A late 80's/early 90's BMW can be the alternate donor (possibly other Euro cars). It's a light green Bosch relay - probably better than original - it's all I use any more.
Some coolant tank info...
Saab 900 and 9000 use the same coolant/washer fluid level sensor as Merkur. The quick connector is different, but that's easy enough to "convert".
New info discovered today.... late 80's Jaguar XJ6 also uses the same coolant level sensor (not sure about washer fluid reservoir). The Jag coolant reservoir is long and narrow, designed to be mounted north-south. Might be useful for some custom-plumbed setup, while still using the stock sensor.
Time to add a couple items to this list....
Oil cooler "sandwich plate" fitting, found on Volvo 2.3 Turbo engines
Hood prop bushing - Ford Focus
External Wastegate - Audi Turbo engine- late 80's - early 90's
Remote Battery box - Ford Tempo Diesel (in trunk)
xr4man
Post by xr4man »
87ish saab 9000 spoiler. nearly identical to a rs500 lower.
any garrett turbo from saab 900 or 9000 (not sure how the mitsubishi turbos would fit)
ian the re-animator
worked_xr
Post by worked_xr »
I do some junkyard crawling and I often find stuff posted so far, but I do have questions about some stuff:
DPDISXR4Ti wrote: '85 - '87-ish Nissan 300 ZX Turbo Compressor housing
late 80's/early 90's F150 or E150 (van) external fuel pump (p/n E7TF-9350-AA)
John Brennan wrote: BMW 5-series difs
DPDISXR4Ti wrote: Oil cooler "sandwich plate" fitting, found on Volvo 2.3 Turbo engines
xr4man wrote:any garrett turbo from saab 900 or 9000 (not sure how the mitsubishi turbos would fit)
Maybe I'm just being dense, but why grab this stuff?
Phil Marshall's customers are looking for the BMW difs to do as he has done.
worked_xr
Post by worked_xr »
John Brennan wrote:Phil Marshall's customers are looking for the BMW difs to do as he has done.
Which model years 5 series are they looking for? Now that Sean M. is doing his BMW E36 LSD diff conversion kits and E30 gear sets will swap in, I suspect E30s and E36s will start becoming good to look for too.
