Scorpio hub conversions 5 x 114.3 / 4.5 rebuilt
Refurbished front and rear Scorpio hub/spindle/bearing carriers redrilled to the more common Ford 5x4.5/114.3. These were stripped and plated black zinc and include all the mounting hardware (rear carrier mounting bolts are not pictured, but are included). Come with stock studs, option is noted. I have brand new bearing kits (Timken front and SKF rear) to install in them.
Front Scorpio hub conversion: $325 assembled with Timken bearings (torquing these is a pain. Requires the same 250lb/ft as the rear). Includes both spindles, redrilled hubs, new bearings and triple lip seal, pinch bolt, and new outer tie rods. Add $30 for high strength 2.5" quick start studs, or send yours at no extra cost to be installed.
Rear Scorpio bearing carrier/hub conversion (bolt-on the XR): $325 assembled with SKF bearings(hub will be pressed in if desired). Add $30 for high strength 2.5" quick start studs, or send yours at no extra cost to be installed. Add $100 for 2wd Cossie 108mm stub shafts (not shown), both RH thread and come with both new and used plated axle nuts.
I'll give a $25 discount if both are purchased.
Tim Spencer
Re: Scorpio hub conversions 5 x 114.3 / 4.5 rebuilt
Bump. Can deliver along I-8 between San Diego and Pensacola FL. Save $50.
Tim Spencer
- Level 5
The tempatation is strong
Adam Escott
Dothan, AL
89 XR with Outcast Body in red
Duratec build in progress(need cams and stand-alone)
89 Scorpio. Needs everything
Dothan, AL
Bump...I have finally moved into my new place and have unpacked about 60% of my garage boxes. That includes all of this stuff. I also procured a set of the front spindle adapters to fit directly onto the XR struts that can be included. Make an offer if interested.
Tim Spencer
Did these ever sell?
These, yes, but I do have another set I can build up. They are silver in color. I'm awaiting a rear set from someone as a core for the rear. You interested?
Tim Spencer
- Level 1
Where can I get the xr to scorpio spindle adapters
Its not what you build, its how you build it.
1988 Merkur XR4TI 393W Turbo Setup
1986 Merkur XR4TI Stock wife's little beater
(I have new XR strut to Scorpio spindle adapters if anyone needs them to compliment these kits)
Curious what they even are? Got a photo?
