EGR Removal
Merkur Scorpio / XR4Ti Technical Library - Check here for answers to common questions, problems and modifications.
zealost
EGR Removal
Post by zealost »
No, this isn't the usual question, about ' how can i remove it'. I'm only asking... WHY remove it? .. and someone told me that it only heats up the [exhaust] or something .. meaning, bad. I'm actually clueless, so i thought i'd throw the question.
Re: EGR Removal
It puts a little bit of exhaust (with little to no oxygen left) into the combustion chamber which gives you slightly better fuel mileage. It is like the engine is slightly smaller displacement. Most cars got fixed for free at the dealer (search emissions recall modification) and now the egr supposedly never activates at all or it is very rare. So I didn't feel bad not even running a vacuum line to it. I just loop a small piece of vac line between ports on the vacuum tree so I don't have a huge leak.
I don't care what anyone else says The A-Team was the best show on TV.
Re: EGR Removal
Exhaust gas is a slightly lower temperature than combustion temperature so adding it to the intake, when needed (per the ECU), lowers the production of Nitous Oxide (NO2) at the tailpipe. NO2 is an undesirable exhaust emission with respect to human respiration.
The EGR is activated only under certain engine load conditions. Keeping it installed and working detracts little from enjoying an XR's performance at various throttle positions.
Link is to excellent description of the EGR by Larry Carley who writes on all aspects of internal combustion engines:
https://aa1car.com/library/egr.htm#:~:t ... ulation%20(EGR,that%20contribute%20to%20air%20pollution.
Re: EGR Removal
EGR is the exhaust, already burnt air mass in the cylinder.
Since it is already burnt, the oxygen content is much less than fresh air.
By mixing this in the cylinder, you're putting inert gas back in, less oxygen, less NOx.
Re: EGR Removal
To answer your question as to WHY you might want to remove EGR, it's mostly just to clean up the engine bay and make it a little easier to get access to things. That's not a terribly compelling reason - it doesn't get in the way too often - and keep in mind, technically, it's against the law.
Re: EGR Removal
^^ Scorpio EGR is away from the engine bay, on the Y pipe about 2 feet from the engine.
Re: EGR Removal
The only time I would consider EGR delete would be if I was totally replacing the ECM with some aftermarket solution like Megasquirt.
On some vehicles just installing an EGR blanking plate will screw up the PFE signal with the result of the ECM implementing a strategy that would yield lower performance.
