Need some tire thoughts
Re: Need some tire thoughts
24" of white fluff ~ Mpls I heard.
Post by zxr250cc »
I lived in Minneapolis on South Bryant avenue in the mid '80's for a year and it is not uncommon to have heavy snow there. I went outside after 18" overnight and the company car was a very large lump in the snow. One day later the streets were fine as they had good equipment and were used to cleaning up snow. That same year I went through San Antonio where they had 1" of snow and were shut down at the airport for a couple of days.
It will be good to see if you like the tires.
JLoft
Post by JLoft »
I’ve had the new tires on for over a week and about 100 miles. To recap they are Falken Azenis RT615+ in 205/5-R15 on stock 1987 wheels. Very nice so far. Much better handling than the very old Pirelli 195/60’s. Speedometer reads about 2-3 mph high at 60 as expected. The Falkens are marketed as a semi-track tire, but get very good reviews for street use even in rain. Only a 200 rated life, but the XR is not my year-round daily driver anymore, so the shorter life is ok.
https://postimg.cc/WtjBghCH
But I’ve now exposed that it’s time to refresh the suspension (I think). I went and dug through my old stash of parts and found this so far (all new parts)…..
2 – Boge 32-495-F front struts
4 – AD-234 (E5RY-18198-A) front strut tower bearing kits
2 – E8RY-5A486-A lower control arm rebuild bushing kits
2 – Neil Swanson inner TCA bushings
2 – E43Z-5493-A front sway bar bushings
2 – E5RY-6038-A motor mounts
1 – E6RY-6068-A transmission mount
So what should be the plan here? Put them all on, I guess? What am I missing? What suspension tricks are needed?
-Jon L
Check with Merkur Depot. Mike had some new (drop in) replacement lower control arms recently. Then save the old arms and parts for backups.
Merkur. It's not all computer.
hbar
Post by hbar »
I had the Falken Azenis RT615+ in 205/5-R15 on my XR with the stock 87 wheels and I liked them a lot.
Dan from Illinois
87 Merkur XR4ti, 5 spd, White, Summer driver
2014 Ford Focus SE, ECU tuner.
FYI, 205s with stiffer sidewall, will give a more bouncy/bouncy ride over por condition roads.
