Help me
Re: Help me
Hello, please tell me how to read engine error codes and decipher them.
Re: Help me
https://www.ebay.com/itm/167333452636?i ... BM0KPYncRl
https://www.amazon.com/INNOVA-3145-Ford ... 0458&psc=1
Merkur. It's not all computer.
Re: Help me
Vovan - get the INNOVA 3145. It is easiest to use.
The diagnostic connector is off the harness near the battery.
Re: Help me
I also see those 7 pin obd1 to obd2 adapter cables available for not very much money. Never used one of them myself but that might be another option.
Re: Help me
I am used to reading errors using LED:) But I need a table with the error codes decodingbrokencase wrote: ↑Thu Apr 10, 2025 8:41 pm Vovan - get the INNOVA 3145. It is easiest to use.
Re: Help me
You can wire up an LED and record flashes. But it is error prone. The Innova unit makes it easy. You should be able to pick one up at low cost as they are old technology.
Re: Help me
I think he's saying he can pull the codes, but doesn't have a reference explaining what they mean.
Mark
Re: Help me
This device is not sold in my country. Does this device explain the meaning of the error codes?brokencase wrote: ↑Sat Apr 12, 2025 2:22 pm You can wire up an LED and record flashes. But it is error prone. The Innova unit makes it easy. You should be able to pick one up at low cost as they are old technology.
Re: Help me
I can't open these links. Casino ads load instead)andyofcolumbusmerkur wrote: ↑Thu Apr 10, 2025 6:48 pm https://forum.merkurclub.com/forum/view ... l&start=15
Re: Help me
They are old, dead links, circa 2008.
Here is the innova manual and it has the code list in it.
https://csr.innova.com/Content/Manual/I ... l_3145.pdf
The codes are not unique to the Scorpio.
The important thing to know:
If an error code appears, and afterwards you think you fixed the problem, run the tests again to verify and to see if any new codes appear.
If possible, driving the car a little between tests is advisable.
Vovan, I do see INNOVA 3145 available on Ebay Poland, if that helps.
Re: Help me
Thank youbrokencase wrote: ↑Mon Apr 14, 2025 10:13 am They are old, dead links, circa 2008.
Re: Help me
What is the fuel tank capacity of the Scorpio?
Re: Help me
I think it is about 14.7 US gallons. But this is just from my memory.
Re: Help me
This is 55.5 liters, I thought it was 70 liters (18.5 gallons). The European Ford Scorpio has 70 liters.brokencase wrote: ↑Thu Apr 17, 2025 4:41 pm I think it is about 14.7 US gallons. But this is just from my memory.
