Modern Review of the (Granada) Scorpio 4x4
anglin
Post by anglin »
I watch just enough automotive reviews on youtube that this one was served to me:
The Ford That Cost More Than Mercedes, BMW and SAAB! Ford Granada Scorpio 4x4 - https://youtu.be/H4K8_4_AAXs?si=XRHmB8Z53PrkI5wk
I checked to be sure nobody else posted it here (it was probably posted to facebook and disappeared into all the noise) and didn't see it.
Anglin email: - anglin at mc2racing.com
www.mc2racing.com
Re: Modern Review of the (Granada) Scorpio 4x4
I also just watched that one the other day, so it must have gotten shared somewhere.
It's not really a balanced review as they're comparing the top-of-the-line Scorpio to the base model Saab, Mercedes, and BMW.
But interesting to watch regardless.
DPDISXR4Ti wrote: Sun May 11, 2025 10:54 am I also just watched that one the other day, so it must have gotten shared somewhere.
The Saab 9000 Turbo was Top of the Saab Line.
The Merc 300 E was not base model.
And IIRC the BMW 528e wasn't base model either.
"it was probably posted to facebook and disappeared into all the noise"
^^Reason I despise Facebook.
He does get one thing right in that video.
Best seats Ford ever put into a vehicle IMHO. Best seats I have ever sat in any vehicle, but I'm sure there may be something high end out there that is better.
He complains about the steering and handling, but its an old car and one wonders what the condition of the the LCA ball joints, struts and in particular the steering column grommet that goes through the firewall. My grommet was perished and it made a big difference when I replaced it. Also polyurethane LCA and sway bar bushings make a big improvement. I'll bet navy beans to credits that he has no rebound buffers in the rear.
He neglected to talk about cargo capacity when you fold down the rear seats. This is another aspect that I like about the Scorpio.
I think the criticism regarding the 150hp is unreasonable. Ford focused on a broad torque curve with this engine. Peak HP is meaningless and I've never found the Scorpio to be underpowered.
brokencase wrote: Wed May 21, 2025 1:17 am I think the criticism regarding the 150hp is unreasonable. Ford focused on a broad torque curve with this engine. Peak HP is meaningless and I've never found the Scorpio to be underpowered.
I agree. Comparing it to modern HP engines, yes, it's low. But also, modern vehicles are much heavier. A modern-day Scorpio would probably be nearing 4000 lbs!
Since the EDIS conversion, I'm very happy with the power output of the Scorpio and any thoughts about converting it to a modern Duratec 4-cyl have been removed from consideration. In fact, I sometimes think about converting the Brat to a 2.9!
Damn Brits in these reviews prate on and on and on, well after each point is made clearly enough in 2/3 words: the Jackie Stewart one; this one; every Jeremy Clarkson one on any auto including the Granada.
DPDISXR4Ti wrote: Wed May 21, 2025 11:22 am Since the EDIS conversion, I'm very happy with the power output.
Is this posted somewhere, I'd be curious to see...Something we may consider if its not too crazy.
my8950 wrote: Thu May 22, 2025 8:37 am
You need to visit the Scorpio section every now and then. :mrgreen:
https://forum.merkurclub.net/forum/view ... hp?t=42772
Vovan
Post by Vovan »
brokencase wrote: Wed May 21, 2025 1:17 am He does get one thing right in that video.
I wonder if EDIS can work with MAP?
Vovan, Yes, I believe it is possible to run EDIS with the standard MAP. It requires translation of the signals between EDIS and the Scorpio stock ECU.
Brad and I spoke about the possibility of this in the forum thread he mentioned.
Vovan
Post by Vovan »
brokencase wrote: Mon Jun 02, 2025 6:38 pm Vovan, Yes, I believe it is possible to run EDIS with the standard MAP. It requires translation of the signals between EDIS and the Scorpio stock ECU.
I heard that EEC4 can't control ignition timing via EDIS. I heard that EDIS can only work with EEC5. Is that true?
