NEW Merkur part of the week
Re: NEW Merkur part of the week
NEW XR4Ti Blower Motors price drop to $149 :
http://www.merkur.50megs.com/catalog_2.html
NEW NOS XR4Ti Rear Sway Bar Links:
https://www.ebay.com/itm/NEW-NOS-610366 ... 3545938247
NEW NOS Cosworth 108mm Differential Stub Shaft:
https://www.ebay.com/itm/203043642728
NOS Cosworth 108mm LH Rear Axle Stub Shaft:
https://www.ebay.com/itm/NEW-NOS-163756 ... 043642728
NOS Cosworth 108mm RH Rear Axle Stub Shaft:
https://www.ebay.com/itm/NEW-NOS-163757 ... 69898267
(used) Ford Sierra Euro Glass Headlight plugs:
https://www.ebay.com/itm/203050720502
NEW Stainless Steel Cosworth RS500 inspired Side Exit Exhaust Outlet:
https://www.ebay.com/itm/NEW-3-Stainles ... 3481292357
NOS XR4Ti Front Brake Pad Wear Sensor Wire Harness:
https://www.ebay.com/itm/NEW-NOS-Genuin ... 3616757772
NOS 1985-1986 XR4Ti Driver's Side Windshield Wiper Arm:
https://www.ebay.com/itm/NEW-NOS-1985-1 ... 3634034888
NEW 3" inlet AFE Pro Dry Cone Filter for XR4Ti with big VAM:
https://www.ebay.com/itm/NEW-aFe-21-910 ... 3596198090
NEW 1989 XR4Ti and 88-89 Scorpio Coolant Tank Pressure Cap Yellow Made In Germany:
https://www.ebay.com/itm/NEW-89-Merkur- ... 3088898186
Assortment of used XR Turn Signal Stalks in various condition (sorted by highest price first):
https://www.ebay.com/itm/85-89-Merkur-X ... 3638008041
https://www.ebay.com/itm/85-89-Merkur-X ... 3089755742
https://www.ebay.com/itm/1985-89-Merkur ... 3089793569
NEW LHD XR4Ti Cosworth Euro Glass Headlight:
https://www.ebay.com/itm/NEW-LHD-Ford-S ... 3106783863
NEW XR4Ti Passenger Side Fender:
https://www.ebay.com/itm/NEW-1985-1989- ... 3103060281
NEW NOS XR4Ti Brake Booster Hose and Valve:
https://www.ebay.com/itm/NEW-NOS-Ford-8 ... 3104898401
NEW NOS Scorpio / XR4Ti Rear Bearing Carriers (rear disc brake style):
https://www.ebay.com/itm/NEW-NOS-Merkur ... 3100531917
XR4Ti & Scorpio All-Metal Aluminum Heater Cores are back in stock at:
www.merkurdepot.com
Bargain priced set of XR4Ti Cosworth Glass Headlights:
https://www.ebay.com/itm/Ford-Sierra-RS ... 3679865722
Cosworth purple temperature sender for XR4Ti:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 3679148907
www.merkurdepot.com
Linky pointy to exhaust tip? Still have hood release cable?merkurdriver wrote: ↑Thu May 28, 2020 3:37 am
NEW XR Hood Release Lever and Cable Assembly:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 3481292357
Both new hood release cables sold a while ago, sorry.milehighXR wrote: ↑Sun Sep 27, 2020 10:04 pm
So this is not a part that you are having made to spec like the coolant tanks, and heater cores?merkurdriver wrote: ↑Mon Sep 28, 2020 1:57 amBoth new hood release cables sold a while ago, sorry.milehighXR wrote: ↑Sun Sep 27, 2020 10:04 pm
[/quote]
No, I wasn't making the hood cables, they were just old stock.
NEW NOS Ford 2.3 Turbo Camshaft Roller Followers:
https://www.ebay.com/itm/NEW-NOS-Ford-2 ... 3131754883
NEW NOS Motorcraft 1/8" Purple Ring Temp Sender:
https://www.ebay.com/itm/NEW-Merkur-XR4 ... 3698418526
NEW NOS Sierra Cosworth RS500 Whale Tail Spoiler Caps ( 2 ):
https://www.ebay.com/itm/203133688208
NEW Cosworth RS500 Front Amber Turn Signal Lenses:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 3770076424
NEW NOS XR4Ti Flush Mount Headlight Covers:
https://www.ebay.com/itm/NEW-NOS-Merkur ... 3785835565
NEW LHD Cosworth Euro Glass Headlight:
https://www.ebay.com/itm/NEW-LHD-Ford-S ... 3770066509
Aluminum Heater Core Matrix with -10AN Side Exit Fittings:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 3225270571
(* One available) Side exit -10AN fittings for inlet / outlet routing behind the dash. Exit the firewall in an alternate location. Set up for engine swaps when the stock heater core tubes end up in an inconvenient spot with the new engine in.)
1989 Merkur XR4Ti Polished Aluminum Coolant Pipe mounted to valve cover:
https://www.ebay.com/itm/NEW-1989-Merku ... 3802747833
(* Last one available in 1989 specific style to eliminate factory capped port.)
Amber Ford Sierra Cosworth / RS500 Front Turn Signal Lenses:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 3789509480
NEW XR4Ti Steering Shaft Joint Assembly:
https://www.ebay.com/itm/193839372045
NEW NOS XR4Ti Ignition Lock and Key Set:
https://www.ebay.com/itm/NEW-NOS-Genuin ... 3838019376
NEW Amber Turn Signals for Cosworth Front Bumper:
https://www.ebay.com/itm/NEW-Ford-Sierr ... 3838557540
(used) XR4Ti Rapido Intercooler Kit:
https://www.ebay.com/itm/RARE-1985-1989 ... 3833438955
