Different way to manually mount tires:
https://youtube.com/shorts/yVQqAw3LmGc? ... UEe8D8zQHo
Harbor Freight Tire Changer Upgrades
Re: Harbor Freight Tire Changer Upgrades
It never went totally on. On that other video (I like that guy's youtube channel now) those reproduction fuchs and cheapie tires went together super easy. Maybe it was just that particular combo. Putting expensive performance tires on expensive alloy wheels I would not attempt to pry against the wheel. Not with levers or a HF tire changer. I would go to a place that sold rims and had the really expensive machine that doesn't touch wheel except in the very center. Then have them balance them. A place here in town that services zero turn mowers and tractors actually stopped installing tires. They send them out now. They had a manual tire changer and did offer that service for years. Until the mechanic/owner injured himself fighting with a set. Some good tips on these videos but don't be fooled changing tires is no joke.Ed Lijewski wrote: ↑Sun Jan 14, 2024 6:46 pm Different way to manually mount tires:
My post was tongue in cheek, although I failed to add an emoji representing it.
The video is clipped before the last spooning or levering of the final bead few inches onto the rim, but I assure anyone that that last inch+ is easy peasy.
Agree in general re not doing manual tire changing on specialty wheels.
But as noted earlier above, using pieces of milk bottle or material with similar slipperyness and sacrificial resistance between the wheel and bead when spoons or levers are inserted worked perfectly for me. That is, tire removed, new tire mounted, with no wheel or bead damage.
