Slightly used ( <2000 miles) Spec 2+ Clutch Pressure plate, friction disc & throwout bearingStage 2+ for a 10spline T-5 Merkur. Replaced with stock type while troubleshooting driveline issues.
$125 + ship from Norther VA
Types of Driving:
Street, Drag, Autocross, Road Race, Pulling, Rally, Drift
Features a multi-friction disc in a full faced configuration with carbon graphite on one side and Kevlar on the other. Bridging the gap between stage 2 and stage 3, the 2+ offers durability, drivability, and engagement quality characteristic of the stage 2, but with a 15-20% higher torque capacity that's similar to the stage 3. So it's more street friendly than the stage 3 while also lasting longer in street use, but with a bit less holding power. Its twin spring high-torque hub is designed to minimize vibrations, for lesser wear along with heat treated components for strength and durability. Great for street, drag, autocross, road racing, pulling, rally and drift.
High clamp pressure plate
Hybrid Kevlar and Carbon-Graphite Friction material
High torque sprung hub and disc assembly
Spec2+ Clutch, PP & TOB
Jim Gosses
86 XR4TI, 165K, T-5, IC, RR, PBR Fronts, T-bird Rear Discs
