Junkyard Shopping List - Feel free to contribute
85xr
Post by 85xr »
was looking today at a 93-94 ranger that had the round tooth timing gears. had the 2.3, so im guessing they should fit?
greg
85xr wrote:was looking today at a 93-94 ranger that had the round tooth timing gears. had the 2.3, so im guessing they should fit?
Yes, '92 - '93 Mustangs and '92 - '01 Rangers will have the round tooth sprockets.
BIG VAM donor vehicle list:
1984-1986 Mustang SVO
1987-1988 Thunderbird Turbo Coupe
1985-1993 BMW 535i
1985-1989 BMW 635csi
1985-1992 BMW 735i
1988-1992 BMW 735il
1987 BMW L6
1986-1987 BMW L7
coupelx
Post by coupelx »
I am running sprockets off a 92 mustang and they are most definately square.
1987 Xr4ti
Re: Junkyard Shopping List - Feel free to contribute
1991 - 2001 Ford Explorer (1st and 2nd gen) - Rear shocks (minimal mods required - search for more details)
2000 - '05 Focus - Front struts (strut tower re-fabrication required - search for more details)
~1990 ('88 - '94?) Chevrolet Cavalier - 12v+ power distribution mounting terminal w/ in-line fuse on orange wire circuit. Located on false-firewall - 7mm socket required for removal.
hEaT
Post by hEaT »
Not a junkyard part per say, but for those with the stock or shorty radiator, the lower hose from a 1992 - 2001 Toyota Camry works great as an upper hose replacement. Got mine from Advance Auto for $20, in stock, no fuss. Part number is DAYCO 71679.
I trimmed what you can see there off the thermostat end. For a stock radiator, you'll need to take some off the radiator end too. The extra length there is what you need for Mike's short setup.
thommi7
Post by thommi7 »
Time to wake this thread up!
Air-Oil cooler from a police cruiser. Search for details.
Wastegate actuator from Saab turbos. Adjustable ;-)
Some new additions to welcome in 2016...
Circa 2000 Volvo S80
- Trunk-mounted battery stuff - Nice heavy-duty + and - cables. Nearby attached 12V+ power distribution box w/ four 40A fuses
'03 - 11 Saab 9-3 Turbo
- Top air-charge hose - 2.75" w/ 90-degree elbow to 2" - Saab p/n 12785081 (Might be useful when using NPR Intercooler)
1st Gen Toyota MR2 ('84 - '89) - Inline Coolant Filler fitting
2nd Gen Toyota MR2 ('91 - '95) - Electric Power Steering (search for details)
Starting off 2017 with a small addition to this thread...
~'95 - 2004 Land Rover V8 Exhaust manifold bolts. They measure 50mm vs. 52mm for stock 2.3T bolts, so close enough. The head is a 12-point, 12mm, so much smaller that the stock 6-point, 17mm. This might make them useful for some headers where clearance is a challenge. They also come with spacers which could be used as-is or machined in some way.
Volkswagon Front struts (search for details)
1998-2008 VW Beetle
1999-2005 VW GOLF IV
1999-2005 VW Jetta IV
It's been awhile, but here's a small addition for when you're looking for new wheels studs just a little longer than stock and have only 30 minutes until closing time at the junkyard and need to come home with something. I only removed them from the rears as they are much easier/quicker to harvest....
2012+ Focus & Escape 12mm x 47mm
2011+ Fiesta 12mm x 45mm
20?? Fusion 12mm x 42mm
Stock length is 40mm for both XR & Scorpio. The spline diameter seems to be around 12.85mm
I'm overdue for an addition to this thread...
4-note horn set from a 1980's - 95 Cadillac
These are known as Cadillac 4-Note Horns. I don't know the specific years, but these horns were apparently equipped in many Cadillacs up into the 1990s. Specifically they appear to be found in Cadillac DeVilles until about 1985 (after which the DeVille was downsized). They also came in Cadillac Fleetwoods and some large Buicks until about 1995. Also supposedly in Oldsmobile Toronados until about 1985.
You can read more about it here... https://www.240turbo.com/horns.html
2003+ Saab 9-3 battery Ground cable w/ dual leads and 90-degree downward routing (cable length approx 24")
2000's 3 & 5 series BMWs - Exhaust hangers which attach to rear sub-frame fastener locations
